Question about Fisher and Paykel Dryers
Dualcare clothes dryer door switch problem - Fisher and Paykel Dryers
  • Fisher and P... Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 01, 2011
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Apr 04, 2014 | Maytag EPICz Electric Dryer
POWER GOES TO IT BUT WILL NOT COME ON AND DRY CLOTHES
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 08, 2011 | Whirlpool Dryers
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer stopped working. Dryed a load of clothes
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 17, 2009 | Whirlpool Dryers
Dryer won't come on
check the door switch in the corner of the door
see if it broke off
Apr 23, 2009 | Kenmore Dryers
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Open Questions:
Dryers Logo
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
