Question about Maytag Washing Machines
Washer dosen't complete cycle it stops 12 min prior to stopping.usually stops at last spin cude shows uc
    Master:
  • 788 Answers
A uC is an unballanced condition. Try to level your washer and make sure the clothes is evenly distributed in the wash drum. If you are still getting the error code then the inertia switch could be faulty. I would have a repair technician look at the machine.
Posted on Jul 08, 2008
  • 2,334 Answers
Can you please provide the model number and manufacturer?
  • Jaime Hernandez Jul 08, 2008
    If you get this code uC, this might not be a DIY. Read below,
    I've found some more info related to this code:
    1. Your washer might has a small shock absorber on the middle left hand corner behind the front panel. it uses a small wiring clip that could be loose, with a type of inertia switch.
    A common issue I've encountered with this machine is underloading. The snubber and springs allow a fair amount of movement. Don't do a few simple items or mixed load in this machine.
    2. The unbalance switch has been known to cause UC codes due to corrosion. I suggest taking the switch out...it'll look like a black strut on the front left hand side of the tub. Unclip the wiring harness and look at it for corrosion. Loss of electrical contact will cause this issue. If you see corrosion, spray a very small amount of wd 40 on it, clean the metal pins inside the best you can, then apply an electrical grease to keep moisture out.
    3. It's possible you have a bad clutch then. If your riser plates turn when the unit is spinning, that will also cause unbalance code to be thrown out. If the risers turn more than two to three inches when it starts to spin, clutch needs replaced.
  • 818 Answers
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer appears to be going throught the wash cycle but the counter is not counting down and it goes no further than the wash cycle. Just continues to do this the whole time. Model # FAV6800AWW
Here are some handy links if you are going to DIY the fix.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Are there any unbalance error codes to the LED display such as dC or uC?
When the washer stops can you place that wash load to a Spin Only Cycle and let me know if the Spin Only cycle completes. Are there any large tub swings in Spin Only cycle with that wash load that cause the Spin Cycle to stop with error codes dC or uC?
Let me know if you can to do some troubleshooting. It would require front panel removal so we can watch the Motor and verify it will rotate the Clutch Pulley CCW in the Spin Only Cycle. If you want to troubleshoot I will give you additional info to begin the process…….Rich
Apr 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Siemens WFXD5201UC Front Load Washer won't complete cycle.
I am having the same problem with my washer. Did you ever get it fixed??
Mar 23, 2009 | Siemens WFXD5200UC Front Load Washer
Neptune XL
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Mar 29, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune washer TI
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out a trying a fix If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unballance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Sep 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
