Question about Maytag MZD2766GES Side by Side Refrigerator
Fridge isnt working.freezer side is - Maytag MZD2766GES Side by Side Refrigerator
  • 472 Answers
Well if this just started you will most likely find within the next 24 hours the freezer will stop also...the unit actually cools from the freezer side first and then the air is pushed over into the fresh food side or refrigerator side as you are calling it... few things you want to check... first there is a opening between the two sides make sure that it is clear and if has an eelctronic damper it is opening if it is warming up in refrig it should be wide open at current time. 2nd if that is good make sure you have no frost on the back wall of the freezer wall and that the fan in the freezer is working . you may have to hold the door switch closed will listening... the fan in the freezer should be running and there should be no frost on the back wall... if there is frost then maybe you have a defrost problem which could be a heater,a defrost thermostat or a timer problem... if there is no frost make sure the compressor is running and you here no clickin coming from compressor .. hope this helps check them items and if you need anymore help post again....
Posted on Jan 01, 2011
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
Auto defrost seems to not be working because the drip tray is dry is it supposed to be like this or wet most of the time freezer is cold but not freezing and fridge isnt cold i have temp gaugers in both...
either un plug the fridge and let it defrost manually, or empty and flush out drain line with a hose or hot water. when it goes into the defrost mode, water should drip into the pan..
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer cold fridge isnt
freezer working,fridge not working,condenser fan ok, compressor running very hot.
Dec 14, 2011 | Whirlpool GS6NBEXR Side by Side...
The freezer part is working good but the cooler side cools but not enough
the damper vent door between the freezer and fridge section isnt opening up to let cold air in from the freezer side to cool the fridge side,its behind a plastic grille near the top between the 2 compartments,there is also an evaporator fan near this and it also needs to be operating to move the cool air
May 24, 2011 | Jenn-Air JSD2789GES Side by Side...
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Jun 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
55 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
