Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Jcthjall@yahoo.commy display shows dr and the door lock light is blinking continously. What should be done to remedy this?
  • 1,998 Answers
Hello
what is the model number of your machine ? Thanks I await your reply
Rick
Posted on Jan 01, 2011
  • Rick Ead
    Rick Ead Jan 01, 2011
    You probably need a door lock mechanism. If you remove the rear panel and locate the lock mechanism (about middle of back) and HELP the gear turn a little it may finish it's unlock cycle. If not just keep turning the gear till the door unlocksif you have any further questions please message me back and please remember when this chat is concluded to rank how this opinion has helped in your appliance situation hopefully with 4 thumbs up Thanks again
    Rick
  • Rick Ead
    and please remember to rank when our chat has concluded how this opinion has helped in your appliance situation Thanks again
    Rick
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Dr is displayed and will clear. oven or cooktop notworking
Error code DR can refer to a door lock malfunction. Try resetting by turning off the power to the oven for at least 5 minutes. Power back up, if the error code continues you may have a faulty door latch, or light switch, or in worst case Electronic control unit.
Dec 05, 2014 | Kitchen Ranges
Why does the dr light keeps binking
Hello Gene Frank - Typically error code DR indicates an issue with the door switch and wiring not communicating correctly or closing properly. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective, contact a professional to move forward accurately.
Nov 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Lights will come on and timer will count down but the washer will not begin
Hello -
Try resetting the unit at the household circuit breaker and confirm that there is power to the unit. If there is power and unit will not start you could possibly have a defective control board, cord or wiring. Do you notice any error codes displayed on the control panel or lights blinking? If so, if panel displays "DR", either the door is not closing properly or it may have a defective door lock switch. However, if panel displays "DDO" the drawer is not closing, magnet may be missing or have a defective reed switch. Typically this is not a do it yourself job and it is something that you want a certified professional to install/repair for you due to safety and liability reasons.
Oct 23, 2012 | Frigidaire GLTF2940ES Front Load Washer
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Sensor lights blink contineously on one side and
Tweak the sensors so that they are pointed at one another. This should stop the blinking and the door should close.
Jan 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
