Question about GE EasyCam Webcam
Device driver software was not successfully installed
Micro sd adapter driver
"device driver software was not successfully installed"
Find the correct driver for your computer and operating system.
Mar 17, 2014 | Kingston Electronics - Others
How to download the Driver of WebCam Model: PK-635M
Download the software from the link provided below.
A4Tech PK-635M driver
*pull out PC camera form your computer.
*open the downloaded file.
*Follow the on-screen instructions.
*When it's successfully installed, please restart your computer.
*After you have restarted the computer, connect Pc Camera to USB on your computer, Windows system prompt to find hardware and automatic install the corresponding driver successful.
Dec 21, 2010 | A4tech PK-635 Webcam
I cant install my bluetooth driver it stop in middle
Is it only Bluetooth driver installation or every installation you try to install . ? If other installation complete successfully but Bluetooth , then you need another driver software source like having another CD or download it from a certain website like the Bluetooth device manufacturer website . If all installations doesn't complete successfully , then you need to scan your system for viruses or repair your operation system .
good luck .
Jan 23, 2010 | Computers & Internet
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
Windows encountered a problem installing my a4tech webcam
you need to update and reinstall your driver
click here (latest version)
(http://www.a4tech.com/driver/A4%20PC%20Camera%20H.rar)
to download driver for your web cam (win 7 compatibility) from official site of A4tech.
since it is rar file you need software like 7zip or winrar
follow the instructions below for proper installation
  • Save driver somewhere where you will remember after download . i recommend that you save it on your desktop , so it will be easy to find .
  • After successfully downloading the driver , do not open the driver file until you make sure the following has completed : ***REMOVE / UNINSTALL any webcam driver from the PC . ( If you forgot to do this part , your driver may not be able to install correctly and successfully later )
  • After the original driver has been removed , open the downloaded file
  • Follow the on-screen instructions .
  • When it's successfully installed , please restart your computer .
  • After you have restarted the computer , plug the webcam into your computer and it will automatically recognize the new hardware.
i hope that this will work
regards,
cseian
Oct 03, 2009 | A4tech PK-635 Webcam
PnPDeviceProblemCode
Even i had this problem.
Follow these steps it may be of help to you.
1. Go to Device manager.
2. Insert the SD card.
3. When the SD card shows up in the device manager with an alert, right click and say disable device.
4. Go to Services and start PNP related services if it is not started.
5. Again right click and say enable device.
6. It shud update the driver software and your device may be detected successfully.
7. Enjoy :)
Cheers,
Raghu
May 27, 2009 | Dell Studio 1537 Laptop Computer PC...
Logitech PRO 9000 installation failure
Click off on the FOUND NEW HARDWARE and continue the installation.
If you have further problems, let me know and I'll assist you to get it going.
Hope this helps. Bud
Feb 01, 2009 | Logitech QuickCam Pro 9000 Web Cam
Please help me
When you say 'It keeps saying that the camera is marked for deletion.', where are you getting this message from? Check device manager to see if you can remove the device successfully.
Do you have admin priveleges to install on your work system? If not, the device drivers may not be properly installed.If you have XP at work, uninstall the Kodak software, then try connecting the device. You can see the camera as a mounted volume through the system drivers.
You can install just the EasyShare software, not requiring the camera drivers, if you choose to, and the camera will still mount successfully.
Jan 02, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Go to makers site and download new driver.
Dec 06, 2007 | Computers & Internet
GE EasyCam Webcam Logo
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
