Question about GE 2-9438C Corded Phone
Ge 29439b 3 line spraaker phone
How do i add speed dile contacts/
  • 97 Answers
Type the number, then hold down the key you want to save it to
Posted on Jul 15, 2008
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
How do I connect wiring and do programming for P1353 timer for my 2 speed pool pump? Thanks,
P1353 is a very complicated for beginner.
Open following link for manual: P1353 starts on Page 25
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
Following steps are general introduction.
You can add a comment about specific steps.
1) Select timer voltage: see page 26 manual
http://waterheatertimer.org/images/P1353-voltage-selection-100.jpg
Timer can control 120V or 240V circuits.
P13553 default voltage for clock motor is 240V.
If circuit breaker that supplies power to timer is 240V, then no change is needed.
If circuit breaker that supplies power to timer is 120V, then change jumper on back of timer to 120.
Timer mechanism snaps out of box using thumb spring located top inside box.
2) Wiring
Open link to see general wiring for P1353:
http://waterheatertimer.org/images/P1353-timer-350.jpg
-Bare ground wires connect to green screw
-Line wires are power wires from circuit breaker.
For example Line wires are 240Volt, and there is 1 black wire and 1 white
Black connects to terminal 1
White connects to terminal 2
Add a jumper wire (short piece of same-gauge wire) from terminal 1 to terminal 3
Add a second jumper wire from terminal 3 to terminal 5
This will put power to clock motor and put power to switches
-Load wires go to 2-speed pump: see wiring diagram page 28
There are 3 Load wires for 2-speed pump: Usually these wires are: Black for speed-1, Red for speed-2, and White
Black speed-1 connects to terminal 6
Red speed-2 connects to terminal 4
White motor wire connects to terminal 2 to complete circuit to motor.
3) Programming.
-Manual shows specific programming starting on page 27.
Timer has 3 circuits. Each circuit is independent of other circuit, making this a 3-channel timer.
-Select different MODES when programming timer
Select MODE 2: circuit 1 and circuit 2 will never be ON at same time, which is intended for 2-speed pump operation.
-Programming steps start on page 30 where you select MODE 2
Actual programming steps are straightforward
-Add a comment if you have difficulties and I will answer.
Also contact Intermatic directly if you encounter a glitch:
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | RTO Intermatic T106M Timer Mechanism Only...
Want to program telephone #s for one touch dileing
The memory instructions are in the fourth column of the first page of the manual at
http://www.home-electronics.net/ge/pc/IB/29369GE1_IB.pdf
Feb 02, 2011 | GE 29369GE1 Corded Phone
I need a free manual for ge business phone model 29439B
http://phone.manualsonline.com/manuals/mfg/ge_appliances/29438b.html
Use the link about to get a manual for your phone. It is really easy. All you have to do is select your manufacturer, Type and model. I hope this helps you.
Please rate me. Thanks
Jamiell
Apr 16, 2010 | Cell Phones
Nokia 5300 express music
Restore ur phone by diling *#7780#
Jul 07, 2009 | Nokia 5200 Cellular Phone
We lost the manual for our 25982EE3-A and need to change to tone
From the Manual!
Tone/Pulse Dialing
NOTE: This setting may be made only with the base.
1. Press the menu/flash button until 41TONE 2PULSE shows in the display. 1TONE is the default.
2. Press the caller id (9 or :) button or the touch-tone pad to scroll to 1TONE or 2PULSE.
3. Press mute/menu to save. You will hear a confirmation tone.
Here is a copy of the manual.
http://www.home-electronics.net/ge/pc/IB/25982EE3_IB.pdf
Jan 16, 2009 | Uniden Cordless Phone
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
Bt quratet 1100 no dial tone
Sounds like the phones have not been registered to the base unit. Look in the manual for directions on how to get the phones and the base unit to talk to each other. Sorry, I don't have any details on theis model to look up the instructions.
Jul 23, 2007 | GE 25831GE3 Cordless Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
GE 2-9438C Corded Phone Logo
314 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
