Question about M-Audio Avid Maudio 99005226600 Studiophile Av 20 Speaker
Studiophile AV20 left speaker doesnt work when connected. its passive, and does function when plugged to another power source. Right speaker cannot support left, or any volume above mid setting, and burns out for about 10 minutes at a time but will not allow left speaker to receive any power. Is this a transformer issue?
  • M-Audio Master
  • 5,603 Answers
Probably NOT a transformer. Most likely in the power amp. Many have a thermal cutout that shuts the thing down when the chip/stick gets to hot. Your description leaves some questions... IF you don't get anything at all out of the left, then look first for a short from the amp to the output jack. This probably has a dual chip amp in it and half that chip may be bad heating up and shutting the whole thing down.
Posted on Jan 01, 2011
  • seditionary_ Jan 01, 2011
    yeah does have a dual amp system, and checked the connection cable on several pairs of speakers... it is fine. The issue is the power amp itself. the thermal cut out is integrated into the chip. This has proved a problem with 95% of the buyers. I just gutted the bloody things and made them passive. Problem solved. :) but I'll never again buy anything from M-Audio/Avid
  • kieranhall Jun 26, 2011
    Where about is the thermal cut out reset switch on the board?
Powering a passive stage monitor
A passive loudspeaker requires an amplifier to increase the power from the mixer.
An active speaker does not require an amplifier and will work direct from a mixer as the amplifier is built into the speaker box.
Jan 20, 2018 | Behringer Pmp3000 16 Channel Audio Mixer
M-Audio AV20 smells like burnt
Yes, it is possible to burn an IC and not the fuse, because of Safety standards, the fuse has the function to avoid a possible fire, but it should deliver all the power needed by the circuit it is protecting, and that amount of power can burn, in this case, the IC.
From my technical point of view, there should not be a problem to connect the speaker to 110 V instead of 220 V, all that might happen is to have less power available at output, I have no idea about the reason of the burnt IC, but, as we all know, they (the IC's), don't need a reason to burn themselves whenever they decide to.
So, the next step, will be to replace the burnt IC, and that is not a simple task, you need a SMD station and some experience in doing such jobs.
Good luck and best wishes.
Apr 11, 2013 | M-Audio AV20 STUDIOPHILE
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
Apr 14, 2012 | Gem Sound TRF152 15 Pro DJ PA Speaker
The left speaker of my M-Audio Studiophile AV20 smells like burning, have taken apart and no wires are disconnected, have tried to find the thermal cut out (if there is one) and cannot find any type of...
If you are smelling a burnt smell, then you have probably burnt out the speaker coil. You would need to take both speakers to a local repair centre in your area and have them checked out. They may be able to repair the speaker or may have to replace it.
Dec 14, 2017 | M-Audio Avid Maudio 99005226600...
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Static and crackling noise from the right speaker
It could be that the input jack is or cable is damaged. The input to the right speaker is from the left speaker via speaker cable. Check that wire and try a new one. All speakers are susceptible to some type of interference. Make sure the cables aren't tangled and free from other powered equipment.
Hope this helps
Mar 30, 2011 | M-Audio Studiophile AV 40 Monitor Studio...
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
I have four active and two passive speakers how do i hook up to amp
Assuming they are ALL mains and not for monitors connect this way:
Connect the passive to the A and B powered outputs. Please read my tip on Fixya regarding hazard of grounding speaker leads on channel A of PMP mixers.
Connect each pair of active speakers to the Main L and R 1/4 inch jacks using TRS balanced cables. Power these speakers from the SAME receptacle or source, even if it means running an extension cord to your mixer from where the actives are plugged in. FAILURE to do this creates a hazard of ground loops and ground bounce that can damage equipment. The Main L and R 1/4 inch jackls can drive more than one active speaker... these are line level signals. Make sure to use TRS balanced cables for this.
Nov 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
M-Audio Avid Maudio 99005226600 Studiophile Av 20 Speaker Logo
273 people viewed this question
Top M-Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
mike_ryan798
Level 1 Expert
Are you a M-Audio Music Expert? Answer questions, earn points and help others
