My compaq evo n610c got some viruses then lost the whole opporating system.cant do anything at all.screen says \windows\system32\config\system missing or corrupt. and I have no original set up cd
  • 22 Answers
Plz restor ur system in back dates
Posted on Jan 01, 2011
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
How do i factory reset a Compaq Evo N610C Notebook
Use Hiren's boot CD to remove the windows password.
http://www.hirensbootcd.org/download/ -> Download link inside.
Burn the CD, and follow the video steps:
Enjoy!
Dec 13, 2013 | Compaq Evo N610C Notebook
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
I have a compaq evo n610c and need a power on password i have lost mine and cant get on my computer
The password exists to protect you, if a thief is in possesion of your computer, and wants to use it. So, there is no way to "bypass" it.
Find your original sales-receipt, to prove that you are the owner, and contact Compaq, and ask for Technical Support.
Sep 03, 2010 | Compaq Evo N610C Notebook
Cant install the ethernet of compaq n610c
If the laptop is newer than 2001, it won't have a ROMPAQ on the hard drive. That was compaq's system BIOS that had to be installed on the hard drive.
If you go into the system BIOS, make sure that the ethernet is enabled.
If it is, then load into Windows and check the device manager to make sure it is there. If it isn't, a simple fix is to do a system restore to the date it worked.
In windows XP, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\rstrui.exe
Aug 08, 2009 | Compaq Evo Notebook N610c
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Jun 17, 2009 | HP L1706 17" LCD Monitor
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
COMPAQ N610C DISTORTED DISPLAY?
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
My some what broken compaq evo n610c
Hi eco953,
I just recently faced the same problem.What I did was I boot up with my original Windows CD that do have repair option.After that if you're repair mode run CHKDSK /R ,this will check your harddrive and repair BAD sector.I didn't realise that I have a bad harddrive and when it read up to that sector it just crash and blue screen POP-UP.
Incase you don't have a Windows CD then the other choice is to remove this harddisk out and connect to other PC/Laptop and run software to check Harddisk fist.
Goodluck,takecare
May 16, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
David Payne
David Payne
