I need a replacement for my burn out svi 3205
SU-G91 amp over load wont reset.
Technics SuG91 uses a couple of SVI ( I think they are SVI ) packs for driving the speakers. These are big black plastic things mounted to the silver finned heat sinks. 95 % of the time, this is the problem. They are not very tolerant to any type of abuse, and all the amp has to do is overheat once and they are toast. 1 The SVI packs are expensive and that amp may not be worth fixing. If you know how to de-solder something, and are comfortable working with voltages that can kill you, you can unplug the amp, make sure it has been unplugged for at least 20 minutes, and gain access to the area of the circuit board that the SVI packs are soldered to. De-solder one of the packs and remove it from the unit. Make sure that when you de-soldered the SVI pack that you DID NOT accidentally solder one solder hole to another ( create a connection from one hole to another that shouldnt be there ) . Re-assemble the unit correctly, plug it in and turn it on. If the display lights up, you have removed the offending unit and need another one. If it is still in protection, then mark the one you took out as "possibly good", and repeat the removal procedure for the other SVI pack. NOTE if you decide to replace the SVI pack yourself, you will need heat sink compound ( that goo that stuck the original pack to the heat sink ). you will need to remove the old stuff ( a rag and some alcohol will work ) before you apply new heat sink compound. If you are uncomfortable with ANY OF THAT, then take it to a shop that offers free estimates. Good luck and BE CAREFUL....Rob
May 06, 2015 | Technics Audio Players & Recorders
Svi 3204
From your question, I don't know if you're looking for an amp board, or preamp board. These two functions may be covered by multiple boards.In any case, they are no longer available. Your unit would need to be troubleshot by a competent audio tech to the component level. If you need more assistance, or would like to inquire about a repair, please visit my website, audioserviceclinic.com. Thank you.
Jun 15, 2014 | Technics Audio Players & Recorders
Svi 3204
If these are model numbers,you would need the part number of the IC. If the IC is specific to Technics, it is most likely to be unavailable. If you would like more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
My father in-law just gave me a stereo system he wasnt using. It came with a technic suv98 amp. I hooked up everything but there is no sound coming out. The output indicators are not even showing...
Checked your amplifier connection, it supposed to be like this, amplifier has 2 audio connectors RED is Right White is Left channel, connectors cable should be connect to audio output of the receiver/DVD/CD etc.. and the other end of the cable connect to the input of the amplifier. hope this help thanks
Dec 04, 2010 | Technics SUV500 2-Channel Amplifier
Redring 3205 wont turn to cold - when control
Take a look at the .pdf document on their site. There will be adjustments within the unit that will assist you in adjusting the tempature. They advise that there could be seasonal adjustments that would need to be completed. I've assumed your model is the Activa 320S as I could not find a redring 3205. Good Luck.
http://www.applied-energy.com/clientfiles/File/manuals/redring/Active%20320S%20Instruction%20Booklet.pdf
Jun 29, 2010 | Home
Samsung yp s3,svi converter
Hi There
I can understand your issue. When you sy unable to transfer the videos to your samsung MP3 player, then the native file format would be .SVI format. So please go through this link and download the SVI setup and convert the file then transfer into your mp3 player. The link is :
http://sourceforge.net/projects/svicoder/files/jSVIcoder/jSVIcoder-0.8/jSVIcoder-0.8.0-setup.exe/download
Please revert for further clarifications..
Feb 18, 2010 | Samsung YP-S3JCB MP3/MP4 player
Video format problem!!
 Just go download emo *** on emodio.com it does all the work
Jan 15, 2009 | Samsung Yepp YP-T9 Digital Media Player
398 people viewed this question
 Grubhead
Grubhead
