Question about Belkin F5D8236-4 Router
I forgot my password and so reset the router by putting the paper clip wire in the little hole. All went well, but I can not seem to work out how to reset a new password. What am I not doing or should be doing?
  • 107 Answers
Well I don't necessarily have enough information to specify what your problem is, I'm considering that you are either referring to your security password, or the password to change the router settings. So, I'll just answer how to work around all three of them.
  • Wireless security password: By default, this setting should be off, and if you do a factory setting reboot (by pressing down AND holding the reset button for more than 10 seconds) it should turn off by itself, thus not requiring you to need it anymore.
  • Router Administrator's password: By default, there is in fact no password, so when you want to log in, all you need to do is press the login button, there is no need for you to type anything in to gain access to your router settings.
If this helped, please give me a thumbs up! And if I didn't answer what you were looking for, please leave a comment and I'll check to see if there's anything I can do!
Posted on Jan 05, 2011
Forgot my password
Well, you can reset the router to factory defaults, then check the manufacturers website to find out the default username and password.
WARNING: You will need to reconfigure the router after resetting. If you don't know how to configure it, don't reset it.
Look on the back of your router, and you should see a "reset" button. Sometimes, all you'll see is a little hole. Put a paper clip in the hole to push the button inside.
Hold the button down for 10 or 20 seconds or so, and the router should start flashing. After maybe a minute, it will be back up and running, and you can use the default login.
Jan 23, 2016 | Computers & Internet
Forgot what the password was for my router.how can i find out what it was?
The default username/password combination for this model is:
username: admin
password: (empty)
If you have changed the password and the default settings won't log you in, then you have to reset your router to factory default. There is no way of retrieving the password otherwise.
Note: you will loose all personal settings during this step!
To reset the router:
1. Put a paper clip into the hole on the back of the unit labeled Reset
2. Hold paper clip down for 10 seconds and release.
3. The router will reboot and you will be able to log in with the default credentials.
Feb 22, 2012 | D-Link DIR-628 Wireless Router
If you have changed the default password to your own password and you forgot the password. You can always reset the router back to its original manufacture setting. However, you will lose your current router setting. So do it with your own risk. Reset location should be a small hole either on back or on the side of router. You can use a paper clip to push in to reset it. Good luck
Apr 16, 2011 | Belkin Basic Wireless Router
remove all the wires except the power wire - - get a paper clip - straighten it and poke it in the RESET hole WITH THE UNIT TURNED ON.
Restart the router - - then go to 192.168.1.1 for username leave blank - for password - put in - admin [ all lower case]
This should get you going.
Gary @ Fix Ya
Mar 28, 2011 | Computers & Internet
How to find forgot user name and pssword inmy router
Take a Norwegian paper-clip and straighten one end.
Turn the router off.
Push that end into the small hole in the back of the router, until you feel resistance.
Push against the resistance for 30 seconds, and release.
This will reset the router to its "factory" settings, including the default ID/password.
Then, reconfigure the router, both the "wired" and "wireless" settings.
Jan 06, 2011 | Computers & Internet
Need to reset netgear wireless router password
Hi, To reset the netgear have a jumbo paper clip and at the back near the antenna there is a hole put the paper clip in that little hole and push till the unit turn off and the is reset to factory setting. The new user ID will admin and a password is admin or password on a lower case. I hope this information will help you solve the problem. Have a Happy New Year HRH
Dec 30, 2010 | NetGear WGR614 Router
Forgot my password how do I re set it
Hi friend,
As you have mentioned that you have forgot the password for the router, so you can reset the router to factory settings by pressing the "RESET" button on the back of the router. It is a very samll button and you need a paper clip to press it.
What you need to do is, you need to take the paper clip, put it in a small hole on the back of the router and press and hold the button for atleast 30 seconds.
Once you release the button, the router will come back to its factory settings.
NOTE: If you will reset the router, all the settings on the router for Ethernet and the Wireless will be lost and the router needs to be reconfigured.
Dec 07, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Forgot custom password, have reset router and also
Hi Friend,
You have do a reset for your router
Step 1:Take a pen or a paper clip and insert it into the reset hole and hold it till the lights are getting flashing
Step 2:Once its flashing with out taking the hand from the reset unplug the power cable of the router and put it back after 10 to 20 secs
Step3: Then follow the below link to configure the Belkin router
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
If you have any Clarification please contact us any time
Regards,
Ayyasam
Apr 02, 2010 | Belkin (F5D5231-4) Router
Is there a way to reset the password to the router? I recently bought a new computer and need the password for this laptop. I forgot the password to the router that was programmed to my old laptop. Thanks
sure..in back, is a small hole that takes about a paper clip wide probe. press for 10 seconds while powered up. Then it resets to admin admin(user name/password). then access it through 198.162.1.1 on browser. should do it.
Dec 02, 2009 | Linksys Wireless-G WRT54G Router
Hi I just purchased a HP laptop equiped with WLAN wireless. However it will not allow me to add my wireless connection in order to access the internet. I cannot remember my password to the netgear.
I DON'T HAVE NO IDEA HOW MANY PC IS CONNECT TO THIS NETGEAR ROUTER. IF YOU FORGOT YOUR PASSWORD OR SOMEONE CHANGE THE PASSWORD. YOU MAY RESET THE ROUTER TO FACTORY SETTING BY AT THE BACK OF THE ROUTER THIS A LITTLE HOLE A PAPER CLIP IS THE PERPECT TOOLS TO RESET IT. THE DEFAULT ID USER IS ADMIN AND THE PASSWORD IS PASSWORD. HOPE THAT THIS INFO WILL HELP YOU SOLVE THE FORGOT PASSWORD AND TO CONNECT TO WIRELESS PROBLEM.
HH
Aug 14, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Belkin F5D8236-4 Router Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
