Question about LG Cell Phones
After charging my LG Vu Plus there was a message on screen that said, "Memory card is ejected. Default storage location is changed from memory card to device." I had not messed with my microSDHC card since first installing it and certainly did not eject it. I cannot get the phone to recognize the card now. I took it out, put it in the adapter,and inserted it into my laptop's card reader (for the first time). I cannot browse files on it. What happened to create this problem? Is there a solution? Btw, the phone was powered off while charging, if that makes a difference. (I usually charge it while power is on.) Happy New Year!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
The memory card has most likely corrupted and no longer will work. you can try to reformat it in your computer, but more than likely youll need a new card
Posted on Apr 10, 2017
  • 3 Answers
SOURCE: LG Vu Cellular phone memory card does not read.
I had same problem-you must push memory card ALL the way in until it clicks!! Also, make sure connection under settings is set to "mass storage"
Posted on Feb 06, 2009
SOURCE: Where do you put the memory card for a LG Vu
you slide off the back of the phone. Remove the battery. Then take out the sim card. Right beneath that is where the memory card is supposed to go. You can easily tell if it's in or not because you have to push it down and hear a pop. Hope that helps, I've had mine for three weeks now!:)
Posted on Feb 23, 2009
  • 13 Answers
SOURCE: LG Fusic 550 Sprint - Memory Card Error with 8 GB Sandisk MicroSD
Believe it or not, a lot of the older phones (an even the newer phones) will not support the 8GB memory card. Most of the phones on the market that support 8GB cards are the smart phones and PDA's. There are a few standard phones that support it but not many. Unfortunately, the LG 550 is not one of them. :o/
You may need to take it back and exchange it for a smaller one.
~*~ Your Rating is Greatly Appreciated *~*
SOURCE: memory card is not accessible in N70 MUSIC EDITION
i used to see this problem many times
this memory is damaged or not supported to N70 any more
-insert this memory to another mobilephone and if it work (mean not spported to N70 any more)
- insert to another phone and does't work(memory damaged)
Posted on Feb 28, 2009
  • 32 Answers
SOURCE: help using 8gb microsdhc card for the lg vu
the vu isnt compatible with the 8,try the 4 or 2.
Posted on May 02, 2009
How to set memory card as default memory storage in my lg g f 7.0 tablet
Your device seems to be running on android to set a memory card as the default storage navigate to settings>storage. There at the top of the screen you should see two options under the first category, default write disk the two options are phone storage and memory card select memory card and then the storage location will be on the SD card.
Hope i helped :)
Oct 08, 2016 | LG Cell Phones
I get an "OUT OF MEMORY" error message on a brand
Hi there most of the time people face this problem during the wrong storage location setting. I am sure your camera default storage unit is camera inbuilt memory. Just go in setting and then select the memory card as default storage location and then click the photo. You will get enough space and not face this error problem. Thanks & let me know the result.
Feb 20, 2011 | Nikon Digital Camera Coolpix S550 With...
Samsung corby GT-S3653 how to change default message storage
how to change default message storage location in samsung corby GT-S3653 because it is showing sms memory full after 200 massages even it is having 500 storage capacity
Apr 05, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
LG VU cu920 can't connect to PC
I have a LG VU as well, and I know your problem perfectly, The LG software is useless for this phone, don't even bother with it. You do need to get a memory card- up to 4 GB is fine, and set your primary storage to the memory card, not the phones internal memory. Then simply connect the phone to the LG data cable, and the cable to the usb of your computer.Do NOT use the LG Suite for this, in fact probably delete it first. The computer will recognize your phones memeory card as an external drive or storage device or drive, and you can simply drag and drop your files, including audio, video, music to and from the memory card and the computer. Remember delet the LG Suite first to avoid conflicts. Hope this helps.
Jul 24, 2009 | LG Vu CU920 Cellular Phone
How can i put pictures on a memory card
This is easy to do on the VU using an LG data cable attached to the phone and into a usb port on your computer. The computer will recognize the memory card as an external storage device, and you can simply copy and paste your pictures to and from your computer on to the graphics file of your memory card. Don't bother using LG Suite, as it is useless for the VU.
Jul 12, 2009 | LG Vu CU920 Cellular Phone
Help with memory card
ok go into mystuff and go to images and find the picture that you wanna transfer dont click on it but push options and scroll down to file and open that up and you will see where it says copy to external and there ya go. but this is just for the lg shine im not sure about the lg vu. this will work because i have an lg shine and i just did it. let me know if this help's ya out
May 07, 2009 | LG Vu CU920 Cellular Phone
LG Vu -how can I tranfer pictures?
It is quite a bummer, but you have to select one picture at a time, go to options, select move, choose memory card, select paste and then when you have moved all of your pictures over to your memory card you can get them on your computer via the data cable. I miss my sony!
Mar 02, 2009 | LG Vu CU920 Cellular Phone
Cell Phones Logo
54 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
