Question about Goodman GMS90703BXA Heater
My door bypass switch broke and I bypassed the switch and it sparked and I undid the switch but now the heater will not run. I got another switch and transformer and they are good. I also checked the fuse and theyare all good what else should I check to get the heater to run the light on the circuitboard is not on.
    Novelist:
    Champion:
  • 230 Answers
Since you have already checked the fuse, you should check the furnace breaker. Protect the door switch wires from any possible shorts first. Replace the door safety switch as soon as possible too.
Posted on Jan 01, 2011
How do you bypass the lamp door cover safety switch on a Samsung DLP tv?
Bare both wires to the switch slightly and twist them together.
Sep 15, 2016 | Samsung Televison & Video
Why is heater blowing cold air?
Could be that your heater matrix is blocked or has air in the system
Mar 01, 2016 | Cars & Trucks
Manual reset switch
sounds like heater is getting too hot make sure if plummed with a bypass it is only open half way if no bypass make sure filters are clean if ok check manual bypass maybe spring is stuck open
Aug 06, 2014 | Hayward H Series Pool & Spa Heater...
My Teledyne Laars LLD spa heaters starts and heats for a couple of minutes thins shuts down. I have tried this several times with the same results. I hear the switch click and then the heater ignites and...
Since the heater fires it sounds like it could be the bypass valve stuck open. The bypass valve allows some of the water to enter the heater, while the rest bypasses the heater and returns to the pool.
If the bypass is stuck open, or broken, it allows the vast majority of the water to bypass the heater and continue to the pool. The water that is in the heat exchanger will become too hot due to slow flow and activate the high limit switch, turning the heater off.
The bypass is located where the pipes attach to the heater and can be checked or replaced if needed fairly easily.
Apr 16, 2013 | Pool & Spa
I have fridgidaire dryer and when I push the start button it just makes a buzzing noise but does not start
Unplug the dryer or disconnect power then remove the two screws securing the top panel to the rear and slide the panel backwards and off.
Behind the drum is the thermal limiter which is wired in series with the motor.
Check the continuity of the thermal limiter and if it reads open, replace it including the high-limit thermostat located on the heater housing (also shown in the picture above). Bypass the thermal limiter for troubleshooting purposes by joining the wires together and insulating it properly. If the dryer starts and runs properly with this setup, the thermal limiter is indeed open. If the dryer still does not start, jump a wire between the COM and NO terminals of the door switch. The dryer should start with the thermal limiter and door switch bypassed, otherwise bypass the motor relay on the control board. Replace control board if the dryer starts with the three bypassed, otherwise the motor is the one at fault and needs to be replaced.
Aug 21, 2011 | Frigidaire Electric Dryer
Heater not starting , think the spark plug connector is not working. Is it possible to run straight to the spark plug and bypass the black box. 55000 btu keryosen heater.
the black box the wire that comes from it and goes to the spark plug is the ignition module,no you cant bypass this or there wont be any spark,make sure though that when unit is powered up theres 120 volts at the input of the black box,(where the power goes into) the box,not on the spark plug wire side either
Mar 13, 2010 | Reddy Heater-30-55,000 BTU Variable
How do I bypass a door switch for my Whirlpool dryer-
take the top loose on the dryer to acces the door switch. If it is the old style it should have a metal suround over the black switch. If the metal arm piece has broke, Ttake it off and tape the white button down to make it run.
Nov 21, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Door switch broke off
no either replace door switch or bypass it ..remove screws at filter opening(if its a top mount filter) pop clips each corner at edge of and lift top switch
Nov 16, 2008 | Whirlpool LER4634J Electric Dryer
Goodman GMS90703BXA Heater Logo
221 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
