Question about Connex 3300 240-Channels Base CB Radio
Hi i have a hd3400 it will come one but the frequency # and display will not show and will not work
    Problem Solver:
  • 44 Answers
There are a dimmer switch on front panel turn it up
Posted on Jan 03, 2011
Hi, why doesnt my Yaesu Ft270R show the frequency? Adding a picture.
That handheld have two ways of display show, alfanumeric and Frequency numbers.
Just change the mode.
See the owners manual.
You can get it here at this link: Print them
http://www.drele.com/media/wysiwyg/magenthemes/catalog_pdfs/Yaesu/FT-270m.pdf
Dec 06, 2014 | Radio Communications
I can't get my uniden bcd396xt police scanner to talk. it will scan, but not talk
Hi Sue,
No it's not a Police scanner, rather a radio scanner.
I will scan, but not receive transmissions.
Two reasons for this:
1. Do you have any frequencies programmed in the scanner, if not, there's your first reason answered.
2. Do you have frequencies programmed but the channels are locked out? If so, there's reason 2 answered.
To unlock channels, you need to press Mon/Hold key to stop the unit from scanning. Now press mon/Hold key and as you do so, notice if you have frequencies programmed and not just a bunch of zeros showing on your display. If zeros are displayed, example: 000.0000MHz, then you need to program the scanner with your favorite frequencies, and I advise that Police should not be programmed. If you do have frequencies programmed, then using the Mon/Hold keys as stated above, go through each channel and unlock each channel using the L/O key, until the L/O icon on the display goes out.
I Hope I have assisted you with your query.
Cheers,
Peter
Mar 11, 2013 | Radio Communications
I am recieving a Heap error, 21E721 : 21EE
Hi Bruce,
Try doing it in the following order:
a) Turn on your radio.
b) Press Hold/Mon key
c) Press No.1 key
d) Press L/O key (the L/O icon should not show on display).
e) Press Hold/Mon key
f) Ch2 should be displayed
Now repeat everything d) onwards until all channels unlocked.
Once you are done, press scan and any frequency stored on your scanner will activate when reception is observed on any of these frequencies, the scan will stop on active frequencies before resuming the scan until another transmission is detected.
I hope this clarifies matters for you.
If you have not programmed any frequencies into the scanner, then it won't receive anything.
Cheers,
Peter
Feb 11, 2013 | Radio Shack Radio Communications
Kenwood tk-768 displays channel numbers. Can I get it to display frequency instead?
Hi Michael,
Simple answer is NO!!!
The way these radios are designed, as with nearly all 2-way radios, only Channel Numbers are displayed. This is to save space on the LCD display for the other icons to fit in.
I hope this answers your query with satisfaction.
Ragards,
Peter
Dec 08, 2012 | Radio Communications
Hello i have a yaesu ft-2900 it receives just fine but when i transmit it shows error. this radio is brandnew
Hi Gerald,
When you say you used the software to download frequencies, do you mean as in from the internet, or did you have to input frequencies via the software on your PC?
There is a difference, that's the reason I ask.
If, by using the software you manually input the frequencies, then did you input both the output and input frequencies or just output for each channel?
If the latter is true, and you are trying to access another user via a repeater, then that is the error.
Repeaters generally, require both the input frequency = the frequency you transmit on, and the output = the frequency you receive on.
Without both frequency pair, you won't be getting out, and no won can hear you, as you are basically transmitting as a simplex station on a repeater allocatted channel, hence the error message on your display.
The radio you have is used by many amateurs & CB operators, and both group utilise repeaters within their allocated spectrum, excluding 27 meg CB, which is simplex only, but with SSB included.
I hope this answers your query.
Best regards,
Peter
Nov 28, 2011 | Yaesu Radio Communications
LOCK ALL CHANNEL
If all channels are showing the lockout icon, and all are displaying the frequency 000.0000, you just need to program the scanner. Entering a frequency will remove the lockout.
If all are showing lockout and programmed frequencies, and the scanner will not function, you need to initialize it. This procedure will erase all data that you have programmed into the scanner and restore it to original factory settings.
- Turn the scanner OFF, then power it ON again. "Multi-system Trunking Scanner" shows on the display.
- Press 0
- Press 1
- Press ENT
"Initializing please stand by" shows on the display for about 5 seconds.
Do not turn the scanner OFF until initializing is complete and the display shows "M000" on the top line and "Bank 0 Ch 0" on the third line.
Need more information on your scanner? You can download/print the operating manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-97 Handheld Scanner
WHERE TO FIND CODE MANUEL
Hi.
To program the scanner do the following:
  • Press "MANUAL" button. The display will show the channel.
  • Keep holding the "MANUAL" button until the display indicates the desired channel.
  • Press the "E" button.
  • Enter the channel frequency.
  • Press the "E" button again. The frequency is now programmed for the channel you selected.Verify that your entry is correct by pressing the "REVIEW" button.
Here the reference guide: Reference Guide
Jan 14, 2010 | Uniden BC248CLT Base Scanner
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
I cannot install my graphic ati radeon hd3400 on windows xp
Requirements to properly install ATI Radeon™ HD 3400 series graphics card: an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable is required
May 29, 2009 | Acer Computers & Internet
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Dec 22, 2008 | Magnum 257 CB Radio
Connex 3300 240-Channels Base CB Radio Logo
60 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
