My PC is an IDE. the dvd/cd burner went bad. I baught this new LG burner today with an IDE to SATA adapter with the needed cables. I installed it all and it wont even come on, not working. So I am guessing that I need a driver for the new LG dvd/CD burner. I have waited for almost 2 years to get a new one and now this. HELP!!
  • 11,361 Answers
It is not the dvd driver problem but more likely to have the adapter issue. The generic Microsoft cd/dvd dirver should be fine, I never have to install and driver for the replacement DVD/CD drive on any of my repair works.
Did you try this setup with another PC?
http://www.cooldrives.com/satoidecofor.html
Posted on Jan 01, 2011
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
How do you install an lg gh24ls70 dvd rewriter into a compaq presario computer runnining windows xp that is 8 years old
If it's a sata connection on the drive you may not have any sata sockets on the motherboard. You will need something like an IDE to Sata adapter like this one: Adapter.
Feb 18, 2012 | LG Computers & Internet
I want to install a CD/DVD RW drive. This is in addition to the installed CD/DVD already in place. The new drive has a SATA connection on the back, and the only available connector is an IDE connector....
There are IDE to SATA adapters and cables, such as this one linked below. IDE to SATA Adapter
You would simply plug this adapter into the available IDE connection on your motherboard, then use the SATA data and power cable to connect from the adapter to the CD/DVD drive. You can look around online for similar products, but they should get the job done!
Mar 05, 2011 | HP (REFURB) HP XW4200 XPP P4 3.4GHZ 80GB...
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Any instructions on how to install the LG(GSA4167B)DVD RW super multi
turn off PC > open left side panel of the PC casing > remove drive slot in front of the case to insert the new one > You find two connectors, the data cable (IDE or SATA) and the power cable (MOLEX or SATA connector), you need to fix the proper data cable one end to the motherboard and the other one to the Drive Connect the proper power cable from the Power Supply Unit then you are good to go :) good luck
Jan 31, 2011 | LG (GSA4167BB) DVD RW Dual Layer Burner
My dvd+rw is not writing discs
install new burning software.check the IDE/SATA cable.maybe the lens need to cleaning
Jul 07, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
No sata l type on my motherboard
the only way i know is to buy a convertor like the 1 from the link
http://www.cooldrives.com/serial-ata---ata-atapi-ide-interface-adapter.html
might be easier to just swap the drive you have if youve just bought it or buy a new ide drive
Mar 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
