Question about Garden
I have purchased a dismantled Robland e300 panel saw. What size are the balls for the sliding table 14mm or 9/16 or can I use either? How many are there? What is the assembly procedure? What stops the balls from from rolling out the end of the table when extended?
karmacanic
  • 16 Answers
SOURCE: Frozen slide mechanism
lubricate it with graphite powder OR silicone spray lube but not both
Posted on Oct 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Posted on Jan 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: I purchased a used table saw and need a
OK first go to Searspartsdirect.com and on the right side of the site type in your model number, this will take you to another page and on the right side of this one you will see that you can view a manual, just about there what I had to do after you click on this is open a free user name account with password before it lets you download the manual, Have plenty of paper handy it is 44 pages long. Let me know if you have any trouble. I viewed it and it is there.
Posted on Mar 15, 2009
  • 82 Answers
SOURCE: need a new chain blade for my electric E300 saw.
The E300 has a 16" chain . Ebay is always a good source for replacement chains
If this helps please leave feedback, if not let me know and I'll try and help some more!
Posted on Jan 26, 2010
  • 10 Answers
SOURCE: missing parts for guard assembly craftsman table saw 133.299315
I sell parts on ebay, I have many blade guards. not sure on your model # you sure it isn't 113.xxxxxx????? "Hokienpokie" ebay, or contact me via email " jimatcavanaungh@cs.com" probably be abble to fix you up, Jim
Posted on Feb 12, 2010
How to change a belt on a robland combination woodworking machine
Anon, change a belt on a robland combination woodworking machine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.robland.com/beheer/public/document-upload/Silverline%20PS%203200%20ENG_compleet.pdf
http://www.robland.com/beheer/public/document-upload/NX%20Series%20ENG_zSchema.pdf
belt changing on robland x31 General Woodworking UKworkshop co uk
ROBLAND Z320 INSTRUCTION MANUAL
Sep 27, 2014 | Crafts & Hobbies
Makita L1011 compound sliding saw with sticky miter table
The LS1011 doesn't have a table angle release lever like the newer models so it's harder too swing the table from angle to angle, this also causes the plastic swing body to crack. Have you loosened the locking screw for the table? The table may have to be removed and the pivet shaft greased. I had this problem with an old Makita Table Saw 10" 2600.
Feb 01, 2013 | Saws
What size is the lower ball joint lug of a 2000 lincoln ls, 14mm or 16mm
16 mm. there is also a 1/2 year model with an 18mm look on the driver door where the latch is and see if your car was produced in may or june if so it is a half year model therefore it will be an 18 mm
Jan 02, 2013 | Cars & Trucks
Slide mechanism is stiff
linear bearing problem
clean them with brake cleaner and compressed air
the balls should roll freely in the grooves inside bearings
push balls into the slots with compressed air to remove the dirt and then a little bit of oil and it should work.
Nov 23, 2012 | Makita 10" Dual Bevel Sliding Compound...
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
Need a new chain blade for my electric E300 saw. What size do I need?
Jan 26, 2010 | Poulan Garden
Purchases a makita compound sa wUSA can i use it in AUStralia
The only obvious problem is that a saw purchased in USA will have a 110 volt motor. Mains voltage in Australia is 220, so you would need to purchase a transformer in Australia to step the voltage down to 110.
Dec 29, 2009 | Makita 10" Dual Bevel Sliding Compound...
What size is the set screw (part #30) that holds thre bushing and prevents the motor from free-sliding up and down the threaded rod?
finally got it. the screw is M5x0.8x8 If I have helped you with your request would you please rate this response accordingly and thank you.
Oct 11, 2009 | Bosch 4000 - 07 Electric Table Saws
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Blade size
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Aug 27, 2008 | Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
