Did you refill the cartridge? If so, then you will need to reset a chip on the cartridge somehow. Usually epson doesn't sell "refill" ink unless it is an EcoTank series printer.
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
For your ip2700, even if you reset your refilled cartridge, they are not going to be usable.
After 4~5 times of color refill, you will see e5 error that cartridge is not readable anymore.
So you need to replace your cartridge with new one somehow.
If you would like to save money, try refill kit by "ROADINK". Not only they are easy, but also the printing quality is good. For your better understanding pls check out my youtube video. And will see how easy ink refill can be done.
Hi there Dell Printer 944 error message 1102 Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message Why does my Dell ink cartridge level still show up as "low ink" after refilling them? Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message. Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems. This post is in no way a validation of refilling ink cartridges. Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges? Most ink cartridges have sensors that report the ink level.The “Low Ink” is usually the last sensor (fuse) before running out of ink. Since the sensors are fuses that open when the ink level drops, they cannot be reset.If you are using refill or remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep getting “low ink” messages. To disable “Ink Alerts” on Dell inkjet printers: 1.Open the Dell printer software (All-In One Center, Tool Box, etc) 2.Go to Settings 3.Advanced 4.More Options 5.In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low ink alert only when the cartridges are almost empty. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
This is because the ink cartridges has a memory chip.It monitor ink levels.Press and hold the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
