Question about Kenmore HE2 Plus Front Load Washer
F11 fashes drum wont turn water styill in machine
  • 425 Answers
This a big and a little bit messy job to do. you can first drain the water through its drain plug usually it is located lower front panel of the machine.
after completely drained, unplug the unit to avoid electric shock and open the lower panel of your machine. this is a little bit tricky to find the screws, patience is required and also screw drivers and other tools. after opening, locate a float switch under it if its working properly and other switches inside. also the important part is to check on its drain valve probably something clogged into it that is why it is not working properly. you need to open the tube pipes to access it.
please refer to your manual on the parts of your machine...
hope i give you an idea...
Posted on Jan 01, 2011
F11 code on whirlpool washer
Motor bearing has gone and heating up so that the position/speed sensor has moved/melted causing the machine to jump about. needs new motor bearings/ new motor.
Dec 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
The F11 error can be difficult to resolve even for us technician's.
The F11 error occurs when the central control and motor control don't talk to each other.
If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Have f11 fault tried to reset and machine starts up, turns a few times, then gives a strange noise then f11 appears and pump starts draining, had f11 few years back and was fuse but remember at this time...
sounds like you've either got a stiff motor or gunk in the drum making it difficult for the motor to turn. When the fuse blows the drum won't turn at all but as yours is trying to turn then throwing the fault up it sounds like something is causing too much resistance
Aug 26, 2011 | Dyson Flowcheck CRO1 Front Load Washer
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Dial keeps clicking around like a clock and drum still full of water
the dial clicks to indicate an error code as it turns the light will fash a code out -likly code will be 5 flashes which indicates pump blockage-check filter
Nov 12, 2009 | Hotpoint BWM12 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Thanks for using Fixya.
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
