Question about Disney Tangled for Nintendo Wii
How does Flynn grab on to rapunzel's hair when he is down in a hole
Once Rapunzel goes to the spot on the ledge with the butterflies and you select A for her to let down her hair, you have to then select Z so that you switch to your Flynn character. There will also be a spot with butterflies below where you have to navigate Flynn over to, then when he is in the right spot, the "A" will pop up, you then hit your A button and he will climb her hair. Note: not all places with butterflies are spots where he can climb her hair. Only areas that have a tree stump jutting out and there are butterflies above and below. Areas with butterflies above and below but DON'T have a tree stump, are areas that Flynn can stand on top of the ledge and Rapunzel stands below and throws her hair up to him. Flynn then can hoist her up.
Posted on Jan 31, 2011
I have a Kenmore sise by side refrig on the left (freezer side) it ices up on the bottom
the drain is blocked.slime builds up in the drain line and then the water freezes in the line,unplug the fridge,melt out all the ice at the bottom of the back panel,you'll see a drain hole there,i use a steemer to blow through the drain line,if you don't have a steemer hit the hole with the hair dryer for a while,then pour hot water into the hole,if the water doesn't drain down the hole try using a turkey baster to blow out the line,or you can try to snake something down the drain hole but be careful,it's made of plastic,when you think it's clear pour hot water down the hole again if it doesn't drain keep hitting it with the hair dryer until the water drains down the hole,sometimes it takes like an hour to free it.
May 11, 2011 | Kenmore Refrigerators
I have a remington R4130, when I opened the package the head came off. I cannot get the top part with the wire to lock in place, any idea how I get it to lock in place?
The wire hinge is a weak point, and my Remington R4130 head also detached at the same point. Getting one side of the wire back into the hinge hole was easy, but to get the other side into the hole (located at the center of the back edge), I needed to use a needle-nose pliers to grab the bent end of the wire and direct the pointed end of the wire into the hinge hole.
Jan 09, 2011 | Remington R4130 Hair Trimmer
How do you get flynn to climb rapunzel's hair w/ wii tanlged game? pushing the A button does NOT work!
Dec 29, 2010 | Disney Tangled for Nintendo Wii
How do you make flynn climb rapunzel's hair?
You have to find a branch hanging off the side of the ledge. Walk over to it until A appears. Then press A and she will tie her hair to it and Flynn can climb up.
How do I get my hair to grow faster?
Chances are, your hair is growing, you may just want to speed up the process. The three essentials to fast hair growth are: lots of water, aerobic exercise and eating mineral rich foods or taking extra minerals in supplements. Taking 22.5 miligrams of zinc daily along with a multi vitamin will speed up the process. Shampooing 1 to 2 times weekly and using products that cleanse gently, nourish and strengthen your hair will keep your hair from breaking. Exercise is so important because heart pumping exercise speeds up blood flow, therefore getting more nourishment to the papilla of the hair and perspiration unclogs the pores and helps to rid your body of toxins. Exercise also reduces stress and helps your body to relax. Drink 10 to 12 8oz glasses of water daily and eat lots of leafy dark green vegetables. Whenever you exercise, be sure to rinse or shampoo your hair 2 to 3 times weekly. If you cannot shampoo often enough, mist your hair with Revitalizing Leave In Conditioner and seal in the moisture with Nourish & Shine. Remember, perspiration has salt and ammonia in it and both are very drying for your hair, so be sure to shampoo or rinse as often as possible. P.S. loose the weaves, glue and heavy gels, and shampoo more often if you want your hair to be healthy!
Nov 23, 2010 | Health & Beauty
Vacuum works but doesn't pickup dirt
there is a clog. check the hose, and the entry to the canister, check the holes inside the canister and check / clean your filter. also remove any threads/ animal hair from the brush so i can freely grab the carpet :)
Mar 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Slow drain in the bathtub, cannot use a snake because the drain hole has an old metal piece that is divided into 3 spaces.
Be best to use a chemical drain unblocker, Mr Muscle or similar. Possible Caustic Soda. Usually all the hair and grime clog up, chemical unblockers usually do a good job of removing this.
Jan 10, 2010 | American Standard Cambridge 5' Americast...
My Kenmore refrigerator is leaking water from somewhere on top down into the main compartment. It's also frost free but develops ice sheets in the bottom of the freezer?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Refrigerators
Clogged vortex holes
I had these same issues. It came down to my husband beating the **** out of it several times. He'd take the canister apart, pound it on the ground, use a hair dryer to blow out as much as we could, a hanger down the top to pull out any hair we could grab. Then I'd use it -- it definitely loosened up some stuff. He'd pounded on it again and more stuff came loose. Don't know if it's fixed, but it's got it's suction back. Now I have have hose suction issues.
It felt good to beat on it a bit.....
Jan 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Digger how to
Hammer rebar into the ground to create pathways for water. Grab a hose and soak the ground to soften it before using the post hole digger. Wait until the water has had a chance to soak in. Raise the post hole digger and drop it, jaws open, into the ground. The jaws will cut into the ground and soften it even more for removal. Continue to use the weight of the post hole digger for the hard work, circling around the edge of the hole. Drop the digger down with force once you've loosened up a circle of soil. Open the handles to grab a bite of earth in the jaws and lift it out. Continue with Steps until you've removed all the loose soil, making a hole 1 foot in diameter.
Aug 27, 2008 | Woodland International Chipper Knife for...
Disney Tangled for Nintendo Wii Logo
668 people viewed this question
Top Disney Video Game Consoles & Games Experts
James Wishart
ptpumpman
NOEL
NOEL
Are you a Disney Video Game Console and Game Expert? Answer questions, earn points and help others
