Question about White Sewing 2037 Mechanical Sewing Machine
I can't figure out what is wrong with my machine. I press the pedal and hear it running but the needle wont go.
That sounds like your drive belt is not working. Try taking the cover off the right hand side of the machine (two screws, one in the side, one on the bottom) and look inside to see if the drive band is on all the way or if its broken. It could also need to be tightened. There should be a screw that mounts the motor and will allow you to tighten or loosen the drive band.
Posted on Feb 20, 2011
I have a Necchi model 537FA. When u step on petal, it won't move. Does this machine have 2 BELTS? I only see one. I have oiled before running.
If you don't have any movement or hear the machine attempting to sew, you may have a burnt out pedal.
You should hear a slight hum when pressing on the pedal. If you don't hear a hum, the pedal is probably dead.
These can usually be ordered from the merchant who sold you the machine.
Apr 19, 2016 | Necchi Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
Needle and take-up lever don't move when I push the pedal
It's possible there's a part loose or broken only a sewing machine repair shop can tell what's wrong
Feb 02, 2012 | Singer Sewing Machines
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Feb 02, 2010 | Husqvarna Sewing Machines
When i press the pedal, the needle wont move and i already oiled the machine
press the hand wheel in. On this machine you pull the hand wheel out to disengage the needle while threading the bobbin and press it back in to reengage the needle.
Jul 11, 2009 | Kenmore 15212 Mechanical Sewing Machine
Machine wont' run or stitch
It is most likely the machine belt is slipping, re tension the belt and you should be fine. Also, just in case the needle has lost it's point change it and put in a new one just to be safe.
Jul 07, 2009 | White Sewing Sew Cute SC20 Mechanical...
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
White Sewing 2037 Mechanical Sewing Machine Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
