Tried to turn on new viera 1080p plasma hdtv on the 5th day as usual there was a small flash of light but the tv did not come on and the standby red light started to flash 10 flashes
  • mjcbishop987 Jan 01, 2011
    thank you for your help i will contact my tv store and have them replace it as it is only 8 days old
  • 6,993 Answers
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in standby mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
Since this is a new TV, I believe should still be under warranty. If its actually under warranty, I wound suggest you return the TV back to the store/shop where you bought it and replace it with another. This problem requires repairs. This will involve disassembling the TV and once the TV is disassembled, then the warranty would be void. But if the TV is not under warranty, then you might want to try the below;
I do not think the defective power board needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 01, 2011
  • Walesarumi
    Walesarumi Jan 01, 2011
    Okay, that would be better. Good luck.
Panasonic viera plasma tv 10 blink code
1. Hold the front panel power button for over 15~20 sec and try.
2. See the youtube video
https://www.youtube.com/watch?v=awnrE3k_G2M
Mar 09, 2016 | Panasonic Viera Tc-p50gt25 50" Inch Full...
Wont turn on
You most likely need a new main board, this same problems happens with most tv's, it happened to mine a week ago
Apr 17, 2014 | Panasonic "TCP42S30 42"" 1080p VIERA S30...
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Red led power light comes on and flashes 10x. TV will not turn on. What is the problem
Its a error code and usually indicates power supply or something loading that down.
Dec 12, 2012 | Panasonic VIERA TC-P42G25 42-Inch 1080p...
Plasma glass broken
Time for a new TV set--it in this model is called a PDP or Plasma Display Panel and the cost of the part alone is more than the set cost when new--not mentioning major labor to replace it.
Jun 15, 2012 | Panasonic viera tc-p60gt30 60-inch 1080p...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
