Question about Olevia 237T 37 in. LCD TV
My Tv has sound but the screen is black. What do I need to do to fix this? Is there a component that needs to be replaced?
  • 11,361 Answers
Yes, more likely to be the either the power supply failure due to bad caps or just failed components, or the backlight inverter boards, but try this first:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Jan 01, 2011
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
Fixing smart tv
I would consider getting a quote for repair. Sometimes it is something simple, other times it is more expensive to fix rather than buy a new one. I say get a quote, because in the long run a qualified repair shop can figure out what what needs to be replaced, rather than spending money on parts and hoping you found the broken component. If you can get your hands on a model that has a cracked screen, for example, it may be worth it to try to swap parts.
The equivalent Samsung model today costs $380.
Jul 29, 2016 | Samsung Televison & Video
Philips flat screen tv
Board for the screen has a bad component or a bad solder joint. It will need to go to a repair shop. It may be cheaper to replace the tv.
Jul 04, 2016 | Philips 47PFL7403D 47 in. LCD TV
What component or components need to be replaced to fix the tv?
Try replacing the inverter board which powers the backlights on set.
Mar 18, 2016 | VIZIO P702ui B3 70 Inch Ultra Smart
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
How to fix black screen on Polaroid 32" wall mount tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 06, 2015 | Polaroid TDA-03211C 32 in. LCD HDTV
Samsung TV model un40eh53000fxza have sound but no picture
It all depends on the connections and cable.
If you are using a HDMI cable and have sound but no picture, then your TV probably needs to be fix.
if you are using a RCA cable or component cable, make sure that you have the correct TV input.
you don't specify what type of TV you have, but if I were you, I'll check the connections first.
Aug 06, 2015 | Samsung 40" 1080p 60Hz LED-LCD Smart TV...
How to fix a black screen on a sony hd tv
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 11, 2014 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Akai LCT2715 Sound
you need to inspect the board, most of the time you can trace the problem according to a deformed component.... bulged capacitor, burnt component (black dust on component and board) or if it's an IC crack or chipped ...
Dec 01, 2008 | Akai LCT2715 27 in. LCD Television
Screen Blackout
Don't bother with DELL if out of warranty, they can't fix it. Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Nov 18, 2007 | Dell W3201C 32 in. LCD Television
Olevia 237T 37 in. LCD TV Logo
81 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
