Hi my fisher and paykel Elba model#WA55TM just stops on the rinse cycle. I imagine its because the water in the tub is not draining.
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
maxrepair1
  • 3 Answers
SOURCE: Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Posted on Jan 25, 2009
  • 99 Answers
SOURCE: fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Posted on Feb 07, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Mar 29, 2008 | Washing Machines
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
