Question about Magnavox 32MF338B 32 in. LCD HDTV
I have a magnavox 32MF338B. It was only used for about 2 months when it stopped working. When I press the power button it just blinks green. There is no picture. Ideas?
4 Suggested Answers
thekleppinge
  • 5 Answers
SOURCE: My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
omecron2001
  • 22 Answers
SOURCE: magnavox 42mf439b/f7, no picture or sound
i have set with same problem in my shop and after troubleshooting i found that the problem is in jack mo dual A91h5mjc. when you plug set in you hear relay and turn on when you push power switch after few sec high voltage supply shuts down making light blink. what they did is separate high and low voltage supply's half one one board half on other to confuse everyone.
Posted on Oct 13, 2012
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Oct 08, 2012 | Timex 1440 Digital Sports Watch - Green
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
How do I change the Waste Ink collector on a Pixma MP170?
Cleaning or changing the pad is a messy project. This ink pad reset will reset the printer ink use conter to new status and your pad full message will be gone. This is a common occurance with Canon printers and the fix causes no harm. I reset my own MP470 about two years ago without incident.
This reset has been sucessful on many MP150 and simular units and should work on your MP170.
The second works on models with different control pads simular to theMP470.
Mar 27, 2011 | Canon Office Equipment & Supplies
Error code 5100 check printer
This is probably a Canon printer and code. If so, it is the "ink waste pad is full" warning. There are work arounds to keep from having to clean the pad. Here are two methods to eliminate the message. The only other ways are to take it to a repair shop or dismantle the printer and clean the pad yourself. Not advised, This is messy.
This works on many different printers.
mp150 and simular printers:
Jan 22, 2011 | Office Equipment & Supplies
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
Alarm light only on only on cannon MP160 (not Blinking)
Ok this may do the trick, can only try.Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Dec 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Printer
Hi there not know if it will work so you go to come back to let us know pleas.
button pressing
Mar 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Magnavox 32MF338B 32 in. LCD HDTV Logo
136 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
