Question about Vosonic VP8870 MP3 Player
My vosonic seems to have a mind of its own about where it will create a folder or subfolder. also somme files have disappeared. Is there away to transfer everything to my PC in one go ? I have hundreds of raw files and I cant keep multiselecting a few gigs at a time onto a usb. When i am transferring I am getting to many "cannot create file" messages, also getting too many corrupted files
How may I create a folder in Outlook?
Create folder in Outlook.com and organize your messages
As soon as you get on Outlook, the first thing that everyone does is to organize their emails. Now, in order to organize your emails, the first task that you need to do is to create separate folders for the same. The present article is about How may I create a Folder in Outlook? You can also create a hierarchy of folders according to your requirement and arrange all the necessary data in a proper format. You can take help of Outlook customer service for creating folder in Outlook.com.
Adding a Folder in Outlook.com:
In order to create a new folder, first of all, you have to:
? Click on '+' in your Outlook Mailbox. It is located on your web toolbar.
? Name the folder as per your wish.
? Click on Enter. Your folder has been created.
To create a subfolder in a Folder, you have to:
? Go to the folder in which you want to create a subfolder.
? Click on 'Create new Subfolder' in context menu bar.
? Name the folder as per your wish and click on Enter. Your subfolder has been created.
Creating a Folder for organizing emails:
? Click on the 'Folders' list and expand it.
? Select 'New Folder' Option.
? Name the folder and click on Enter. Your folder has been created.
Re-Arranging the Folders in Outlook.com:
It might happen that you create two folders independently and then you may realize that one of the folders is the subfolder of the other folder. You don't need to worry under such circumstances. All you have to do is follow the below given process:
? Click on the 'Folders' Tab in your context menu bar.
? Select the Folder by clicking the left mouse button, which you want to make the subfolder of another Folder.
? Now drag the Mouse Pointer to the Folder under which you want to make that folder, a subfolder of.
? Drop the subfolder on to the folder.
? Releasing the mouse button, that folder will become the subfolder of another folder.
Visit-
Outlook Technical Support 1 844 449 0455
May 26, 2017 | Computers & Internet
I want two inboxs in outlook express 6
You cannot have 2 folders / inboxes with same name. But you can have may inbox folders if you want. Just give them different names. You can also create rules to automatically sort new mail into different inbox folders. The new inbox is created as a subfolder of yor current position. File, New, Folder Give it a name If you are already in the INBOX, new one will be a sub folder.
Mar 04, 2011 | Microsoft Windows XP Professional
In Outlook 2003, I want to export my functional mailbox, all it's directories folders, folders and subfolders, e-mails included in those folders with their attachments in some cases in them and also,...
Hi Tony.
A microsoft server folder is meant to be exported to a computer with Microsoft Exchange installed. That is useful only if the The Outlook Address Book and folders are kept in an Exchange Server mailbox on original computer.
Export as PST and choose the include subfolder option even if you export to Microsoft Exchange.If the Outlook profile on the new computer has a Microsoft Exchange Server and you want to keep all of your data on the just copy the folders from the new .pst file to a location under Mailbox - Your Name in computer with MS Exchange server.
Simply choose export folder to a pst. Ensure that you have ticked that box that say include subfolders, or subfolders won't be copied.
Here the step by step:
http://office.microsoft.com/en-us/outlook-help/copy-the-outlook-folder-structure-to-another-computer-HA001116603.aspx.
http://support.microsoft.com/kb/287070.
Aug 09, 2010 | Computers & Internet
My Inbox comes up blank white and my profile has disappeared. How do I fix? Was I hacked? How do I restore?
It seems to be an issue with the temporary internet files folder. Please follow these steps a. Create a new folder to store the files. For example, if you want to store the files in a folder named temp123 on drive D, create the following folder D:\Ietemp or create it under c. b.Start Internet Explorer c.On the View menu, click Internet Options. d.On the General tab, click Settings e.Click Move Folder f.Click the folder you created in Step a g.Click OK, click OK, and then click OK again. h.Restart your computer.
Now, check your emails. I hope these would fix this problem.
Mar 15, 2010 | Computers & Internet
Jensen MP3 Capacity issue
As the root directory is already full, you will first need to move or delete some files from your root directory before creating new folders in the root directory.
Hope it helps. Let me know how you go.
Jan 02, 2010 | Jensen Audio Players & Recorders
I'm told the directory or file canot be created when I try to drag a picture to the pandigital folder even though I've already copied about a 100 images using the same method.
I have a Pandigital too and although I don't think the users guide mentions it (major oversight on their part), the root directory on this thing can only hold a limited # of files/folders (mine is limited to 108) If I understant it correctly, it's due to the fact that the pandigital uses a FAT (file allocation table) storage method - not that the reason matters. The solution is: make folders in the root directory (you could have up to 108 folders on my pandigital) and I believe each subfolder can have an unlimited number of files in it. I just call my subfolders "Dec 2009 additions, Jan 2010 additions, etc). The Pandigital will randomly cycle thru files in each of these subfolders just as if they were in the root directory. Hope this helps.
Dec 25, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i update the firmware for the VP8870? Ive already downloaded the zip file. All my video files suddenly disappeared! Anyone know why?
While performing firmware update all data will be erased !
See the manual on page 36:
Vosonic VP8870 manual
The firmware update for the player is PMP.VP8870-1.0.0.B2.mtg :
Since you've downloaded the zip file, were you able to unpack it with
Winzip op Winrar ?
When using XP you can unpack by:
1. [Right click on the zip file] Open with > Compressed maps [left click on Compressed maps]
2. The next screen shows the opened zip file. On the left side the
folder task manager can be opened ( Folders / Maps in the top bar not selected): "Unzip all files" : follow up the Windows unzip wizard and
remember the location of the files.
How to do the firmware update is explained in the pdf file "How to update 1.0.0-B2 - VP8870 .pdf", added to the firmware update in the
zip file.
Remember:
Sep 12, 2009 | Vosonic Audio Players & Recorders
I want to move outlook personal folders from pc
Export it first from outlook for a current copy making sure you check mark "include sub folders"- then copy it to the taget PC, then import it back on the new pc from import/export in Outlook.
Make sure you get all of the personal folders, contacts etc.
if you need the steps how to do it, here they are:
To export an individual Outlook folder, such as the Contacts folder or the Calendar folder, follow these steps:
1. On the File menu, click Import And Export.
2. Click Export To File, and then click Next.
3. In Create a file of type click Personal Folder File (.pst), and then click Next.
4. In Select the folder to export from, click the folder you want to export. Click to select Include Subfolders if it applies, and then click Next.
5. In Save exported file as, click Browse to select the location of the .pst file to receive the data that you want to export. Or, type the path and file name, and then click Finish.
How to import .pst file data
To import a .pst file into Outlook, follow these steps: 1. On the File menu, click Import And Export.
2. Click Import from another program or file, and then click Next.
3. In Select the file type to import from, click Personal Folder File (.pst), and then click Next.
4. In File to Import, click Browse to locate the .pst file that you want to import, and then click Next. If you know the path, type it in the box.
5. In Select the folder to import from, click the folder that contains the data that you want to import.
If the folder contains subfolders, and you want to include this data in the import process, click to select the Include Subfolders check box. If the destination for importing is the currently selected folder, click Import items into the current folder. Otherwise, click Import items into the same folder. This creates matching items in the destination folder that you select.
6. Click Finish.
and also try this link Hope this helps,
Thanks,
Prem
Feb 18, 2009 | Microsoft Office Outlook 2003 for PC
I want a code for a program.the program is "Finds out all the html files in a folder including subfolders and writes the file details to file like file name, file path?"
Just download a Program Called Clipname It's Freeware, and it Creates Text files of everything you Select & Highlight.
Then just use the Windows Find Files & Folders Util & Use the following search String in the search field :
*.HTML
That will find all folders with HTML Files in, then all you do is Select & Highlight them all & Right Click, choose Clipname & whatever the type of information that you want it to create in Text format.
Dec 12, 2008 | Computers & Internet
Photos will not upload from camera to computer
Go to Desktop/MyComputer/Pana(or it may say USB Drive, or DCIM, and click on this external drive Icon.
You are now looking at the camera contents as if it were just another file folder on your PC, and behaves the same way.
You will find your pics in a sub-folder under a master folder, common for all camera file structures, named DCIM. You can drag and drop individual pic (jpg) files or whole pic subfolders from the camera to a place on your PC, usuallly Documents/Pictures.
You can do all other folder/file operations on this Camera Folder/Pic files you can do with those that exist on the PC like;cut, past, delete, rename, etc etc.
When you take you next first pic from your camera, after moving or deleting a pic subfoler under the Camera's DCIM master folder, the camera automatically creates another subfolder. Each subfolder holds 999 pics. The camera will atuomatically create a second, third, etc subfolder for pics 1000 to 1999, 2000 to...etc.
Nov 12, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Vosonic VP8870 MP3 Player Logo
41 people viewed this question
Top Vosonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Vosonic Audio Player and Recorder Expert? Answer questions, earn points and help others
