Question about Kenmore Dishwashers
My husband removed the inner panel from the dishwasher door to see why the "door open" light was on after he changed the front panel from white to black. He shut the door without the inner panel and now we cannot open the dishwasher!
  • Kenmore Master
  • 3,247 Answers
It would be helpful to have the full model number of the dishwasher.
The trick would be to drag the dishwasher out from under the counter and open the foot plate and the spring assembly. Hopefully you may be able to lift the door from the bottom hinge and release the tounge of the door latch.
Posted on Jan 01, 2011
Can I replace the door handle on my dishwasher?
  • i think you can but the only way to be 100% sure is by separating the inner part of the door from the outer. to do this remove the screwsalong the sides and rop of inner panel of the door leave the two screws securing the latch in place. as you remove the screws you will need to support the outer portion of the door, i do this by standing in front of the machine and with the door partially open and againdt my knees while reaching in and removing the screws this help to keep the two halves of the door sandwiched together untill all screws are removed at witch point th e door can be closed and the outer part of the door carefully separated enough to check for any wiring that may be attached to the door and or control panel. I recommend having someone to help you with holding the door together.
Aug 09, 2015 | Bosch Dishwashers
How to replace front metal panel
Usually (in most Whirlpool models), if you open the door and look, you will see 8 to 10 screws around the perimiter of the door. Remove those, and the outer door panel will come loose from the inner panel. Now just lift the door up a little bit (an inch) to remove it from the 2 catches at the bottom, and you should be able to remove the outer door panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 15, 2015 | Whirlpool DU1055XTS Built-in Dishwasher
The door on my aeg 40850 dishwasher is jammed shut. How do I release the latch or remove the door?
remove the top two screws at back, lift up about 5 degrees pull back, then you wll see the latch pins remove bolt/s,lift up trim{if it has some} and the door will open then remove inner door screws to get the front panel off to get at the latch
Jun 30, 2012 | AEG 24 in. Favorit 40850 Free-standing...
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
My maytag dishwasher's "clean light"
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back and let me know
Jul 26, 2011 | Microwave Ovens
How do i get back inside door cover off
This will be the same for the back even though it is for the front door....you just don't have the master switch...and a tool that looks like a flat tip screwdriver with a slot in it will help to remove the door panel without you breaking off the tabs that secure the panel to the door. You can get it at any auto parts store for about $6.00:
  1. Open the front door glass so that the distance from the top of the front door glass to the upper part of the front beltline molding is 8.3 inch (210mm).
  2. Disconnect the negative battery cable.
  3. Open the inner handle cap using a small screwdriver, then remove the screw.
  4. Remove the inner handle cover.
  5. Disconnect the door lock switch connector.
  6. Remove the inner garnish.
  7. Remove the cover, then remove the screw.
  8. Remove the lens cover, then remove screw.
  9. Disengage the clips from the front door using a fastener remover.
  10. Pull the front door trim upward, then disengage the tabs from the front door.
  11. Disconnect the power door mirror switch connector and the power window main switch connector.
  12. Remove the courtesy light.
  13. Remove the front door trim.
  14. Remove the switch panel from the front door trim
  15. Remove the hole cover.
  16. Remove the screws.
Aug 30, 2009 | 2005 Mazda 6
GE GLD5560 won't start
Although this post is old, I will help anyone else that is searching for the answer. I too had this problem but after looking at the schematics for this dishwasher, I could see where the problem was.
First, open the door and remove the eight screws that hold the inside cover to the front door on. BE CAREFUL. There are wires attached from the front panel of the door to the inside panel for the soap dispenser. Close the inside panel by slowly raising it up into its closed position and locking into place. Looking at the front panel from the inside, there is a black box at the top with a white PLASTIC PIN. This pin activates the "CLOSED" signal to the control unit. Push and HOLD the white pin DOWN until the system resets. If this does not work, you may need a new unit which runs about $6. After reseting the system, raise the front panel slightly and press and hold RESET/START for 5-6 secs. Now, with a second person holding the inner liner against the machine tightly, I started a cycle and it worked fine. Unlock the inner panel and slowly lower back down and replace the 8 screws.
It's really very simple 10 min fix. the reason this happens is due to the flawed design of the SWITCH PIN, which is not rigid enough. It tends to move side to side and become stuck. A better quality PIN assembly would solve this issue for GE forever.
Have fun.
Apr 22, 2009 | GE 24 in. GLD5560LSS Stainless Steel...
Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Nov 05, 2006 | Kenmore 24 in. 17602 / 17604 / 17609...
Dishwashers Logo
42 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
