Question about Intel Motherboard
Display driver got a motherboard with no video card socket. it only got 2 white pci socket and about 2inches long brown socket. video is onboard so with the sound.on his stickers the board model number is L41GVM6. it have 2 looks like chips, intel and sis900. it is a p4 with socket 478b. how i can get the video driver to boost the color and resolution?
Svdsv
Posted on Jul 09, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
Can a PCI video card be installed on the Intel SE7501BR2 server board? My onboard video has color problems. I tried a known-working PCI video board after turning off onboard video, but got no video...
Most of the time you'll need to change a setting in the BIOS to force the computer to recognize the PCI slot first. Try going through your BIOS settings until you find it. It should be something like "Display First" or Primary, and it should be set to onboard graphics. Try changing that to PCI and see if that fixes your problem.
Aug 29, 2011 | Intel Server Board SE7501BR2 Motherboard
Ive installed the ati his radeon ice q graphics card and my computer will not boot,Why?
hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Jun 07, 2011 | MSI KT4V (MS-6712) Motherboard
How vdo i tell what kind of slot my mainboard has to add video card? the onboard went out.
Brown Colored slot represents AGP
White Colored slot rpresents PCI-E
AGP:
PCI:
Jan 12, 2011 | Computers & Internet
Whart can i do with my mother board no display
Do you mean that the onboard video isn't working? The motherboard has a PCIe x1 slot and 2 PCI slots so you can purchase an aftermarket video card to get around your problem.
Oct 17, 2010 | Intel D915GAG Socket 775 Motherboard -...
I've lost the onboard video for my Intel D915GAG. I've installed a PCI video but still nothing. How can I disable the onboard video so it recongnizes the new video card?
Hi
You can disable the built-in video card in BIOS
The BIOS is accessed by pressing the F2 key
Then     Advanced > Video Configuration Menu
And set Primary Display Adapter>PCI
            Primary Video Adapter>Ext PCI
And Exit Saving Changes
Aug 18, 2010 | Intel D915GAG Socket 775 Motherboard -...
Onboard video not working
get a pci video card.to replace on board video if mobo has pci-e slot.if not get a new mother board!
Dec 18, 2009 | Intel D915GAG Socket 775 Motherboard -...
All I have is a PCI video card not an express. how do i get the board to display on the screen with my video card. I cant see the bios
Is there an onboard video to this motherboard? If so hook up your monitor to that first and go into the BIOS to disable the onboard so when you restart it should go to your PCI Video card.
Sep 30, 2009 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
NO VIDEO
Are you using the onboard video or a display card adaptor?
1. If you are using the onboard video then try installing a known working PCI or AGP display card to test if the problem is onboard video or the actual motherboard.
2. If you are using a display card then try another known working display card (PCI or AGP) to test whether it's your displaycard that is faulty.
3. If it still doen't work then try removing your memory modules on the motherboard and replace them with known working memory.
4. If it still doesn't work then try removing your CPU and reinserting it again (be carefull as you do not want to damage your CPU!).
5. If it is still not working then you may need to replace your motherboard or take your PC into a repair facility.
Thanks
C
Apr 03, 2009 | Cornerstone FIC AM37-L Socket A XP...
Problems with the screen
If you take the side off the pc case and look inside, you will see the back of where your vga lead is connected to from the monitor, if it is straight into the the motherboard, you have onboard graphics, if tou see your lead connected to agraphics card fitted into a brown (AGP) slot or a white (PCI) slot, then you have a seperate graphics card. If you have onboard graphics and suspect it is the graphics then you can fit an AGP graphics card and dissable the onboard graphics in the bios set up.
Aug 23, 2007 | HP (D7580-60003) Motherboard
Intel Motherboard Logo
308 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
