Question about Apple iPhone Smartphone
I have reseted my iphones all data and settings,after that my iphone stuck in apple logo.what can i do?
    Novelist:
  • 141 Answers
Make sure you got latest itunes on your comp & its all switched on and powered up then power your phone off, hold down the home button (front of phone) and while still holding plug phone into comp & itunes should bring up message saying phone has been detected in recovery mode and will give you an option to restore your iphone, continue with this option and restore you iphone as a NEW iphone. dont disconnect the phone until you have completed the whole process- itunes will notify you. Hppe this helps!!
Posted on Jan 01, 2011
Tip
My Apple Iphone wont turn on. What to do when Iphone is freezing.
Hi.
What do I do if my Iphone does not start up anymore?
Here basic troubleshooting:
1 Try turning Iphone off, then back on. Turn it off by holding down the Sleep/Wakebutton until you see the red slider on display, then slide the finger across theslider. To turn iPhone back on, hold down theSleep/Wake button until the you see Apple logo on display.
2 Try pressing and holding the Home button for about ten seconds. This will close a frozen application or a stuck process. After this restart the iPhone following thesteps on point one.
3 If the above did not work, try doing a reset. Hold down the Sleep/Wake button and the Homebutton at the same time for about 10 seconds. You may see ared "power off" slider appearing on screen, then you see the display going black. Donot release Sleep/Wake and Home buttons until you see the Apple logo appearing on display. See picture below:
4 Reset all settings: Tap Settings>General>Reset> Reset All Settings. This will reset all settings to factory default. Data and media files will not be affected.
5 If that does not fix the problem, then try deleting all content and settings.
Tap Settings>General>Reset>Erase All Contents and Settings
This will delete all media and data. All settings will also be reset to default value.
6 Try restoring iPhone using the latest version of iTunes.
Connect iPhone to the computer using the data cable. When you see the IPhone in the Source list, click on Restore in the Summary tab.
If that did not work, repeat steps from 4 to 6 once more. If Iphone is still frozen, unplug it from pc, and try restarting the Iphone. Also reinstall Itunes and connect Iphone to pc again.
Ifrepeating the steps 4 to 6 did not fix your problem , then the Iphone isfaulty. In that case take it to a local Apple repair shop, or call Apple servicephone number listed on the user guide to arrange repair.
If the Iphone is faulty, sometimes reinstalling Firmware can fix it, but that, that is a risky procedure that will invalidate your warranty and damage the IPhone beyond repair. Better calling Apple before bricking the Iphone.
For this reason I will only post links on the argument.
On firmware update see:
How To Install IPhone Firmware
IPhone Firmware Download Links
Regards.
on Mar 22, 2010 | Apple iPhone Smartphone
How do I reset my iphone
Generally speaking, you need the Apple ID to reset your iPhone. iPhone needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPhone, you need to enter the Apple ID when your iPhone reboots.
reset-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To reset iPhone without Apple ID, you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone. The following steps will show you how to do that.
  1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
  2. After that, turn off you device. Press and hold the Home button for 3 seconds.
  3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
  4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
  5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPhone, you will get all the data swept from iPhone, and you can restore the files from your iPhone, iTunes backup or iCloud backup. However, you can't backup iPhone to iTunes/iCloud without Apple ID before you reset your iPhone . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPhone after factory reset without Apple ID.
via How to Reset iPhone without Apple ID
Aug 08, 2016 | Apple iPhone 5
STUCK WITH APPLE LOGO
Sounds like the firmware is corrupted, try putting the iphone in dfu mode then reinstalling the firmware in itunes.
My Youtube Channel
Click here for live technical support
Mar 12, 2013 | Apple iPhone 3G
My iphone screen is stuck. I am in the "phone" area and would like to make a call. But, it is stuck on the list of recent calls, and only gives me the option to "Clear all Recents" or...
Do a soft reset Hold down the 'home' and 'power' buttons simultaneously till the screen goes black and you see the apple logo again ... that should fix it .
Hope I helped :)
Mar 09, 2011 | Apple iPhone Smartphone
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Apple iPhone 3G
Stuck on Music and wont go to the main menu
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software.
Jul 24, 2009 | Apple iPhone Smartphone
My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
Jul 19, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
90 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
