Question about Philips BDL4225E/00 42 in. LCD TV
When we turn it on the green light comes on for about 6 seconds then it shuts itself off again
  • 608 Answers
It could be a problem with the power supply board.
Posted on Jan 01, 2011
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Philips BDL4225E/00 42 in. LCD TV Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
