Question about MagLite Mag-Lite& Flashlight
I had two maglite flashlights, 1 is a (2)D cell light and the other is a (3) D cell light . I went to replace the batteries and I can not get cap off the back ends of both. I think the batteries may have corroded. I tried from the other end but cant get the retention ring out . Any easy solutions?
  • 784 Answers
The batteries will only go out the bottom -- any attempt to remove the top pieces will most likely result in damage to the light itself. to help in the removal of the BOTTOM cap -- you can try and use a little heat from a propane torch ( not much ) and if you place the end cap into a vise you should be able to get both hands on the top part and give it a good twist. -- if the batteries are if fact corroded in there, get a 2x4 and place it on the gound and tap the flashlight down on it,, this may or may not shake them loose,, all just depends on how long they have been in there. good luck.
c...
Posted on Jan 01, 2011
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
1 "D" cell battery is corroded and stuck inside.
Here are the instructions:
http://www.maglite.com/pdf/CustServ/CD_switch_repair_8_0410212004718132.pdf
If you remove the tail cap (the part that you unscrew to put the batteries in the flashlight) and the head assembly (the part that has the light bulb) you should be able to push the battery out. Wear some of those disposable latex gloves as that chemical that comes out of the batteries is very corrosive. Or at least wash your hands really well before touching anything, especially your eyes. Good luck.
Nov 16, 2010 | MagLite Mag-Lite& Flashlight
I cannot get the cap off to replace the batteries of my mini maglite 2 cell AA
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp
to find the nearest warranty/repair center.
Gary
Nov 14, 2010 | MagLite Mag-Lite& Flashlight
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Flashlight only works when end cap is partially on. Will not work when cap is fully screwed in. New batteries installed.
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Dec 05, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
Keeps turning itself off when adjusting beam
It sounds like the spring in the tail cap may be depressed which would cause intermittent contact with the negative end of the Batt. Shake the flashlight vigorously, you should NOT hear ANY noise. If you DO, take the end cap off and pull on the spring, you are trying to stretch it out a bit, replace the cap and shake it again. Go through these steps until it is QUIET when you shake it.
Also make sure there's NO CORROSION at the Positive and Negative ends of the contacts.
Maglites are pretty user friendly and the best light money can buy. I have the rechargeable model which I carried for 21 years during my tour in law enforcement.
Anyway, if it still refuses to work properly, go to; www.maglite.com they are based in California. They will help you get it going. Good luck. :)
Apr 12, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
MagLite Mag-Lite& Flashlight Logo
115 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
