Question about Panasonic CT-36HL43 36" TV
Panasonic TV Hi Marvin, Did you ever get a solution to your problem with your Panasonic CT-36HX42F? Mine just broke, too! Thanks, josephatl@hotmail.com
Good mornig,
Actually, I was helping my son-in-law ... I never got an answer here, and he called a repairman, which fixed the problem, but cost him approximately $300.
Posted on Jul 08, 2008
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
CT-36HX42F
I had the same problem. Sometimes the processor gets overheated, particularly when dealing with high definition signals. Unplug the television from the power strip or wall outlet and it should reset everything. When you plug it back in it should work. Not a long-term solution, I know, but it will get your TV working again.
May 07, 2008 | Panasonic CT-27SX11 27" TV
Neet a part for Panasonic CT-27HL 14J Television
Call panasonic, they are great at at solving this type of problem, if you get a good tech rep they will quickly find it for you.
good luck-----------------------tomtaso
Nov 26, 2007 | Panasonic CT-27HL14 27" TV
Universal Remote
please open it & get the reply.
http://www.remotes.com/
Oct 18, 2007 | Panasonic CT-27G11 27" TV
Panasonic CT-32SL14 32" TV
do you have any electronic skill ????
Jul 20, 2007 | Panasonic CT-32SL14 32" TV
Panasonic CT-36HL43 36" TV Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
