Question about Toshiba Televison & Video
What channel do I play when I connect a DVD player to Toshiba TV 32CV700A
  • 312 Answers
HI,
What Channels do you use. None.
Plug the DVD player into Video 1 or 2 or More as below. Or Connect it with a HDMI cable.
You should have something like this on the back of the set. Video 1, Video 2, Possibly Video 3. HDMI Input, maybe and HDMI Output, Cable, etc, etc.
When you turn on the TV You should be able to see a menu that shows inputs for you to choose.
When you choose the one you are attached to, your picture will come up.
Hope this helps,
Happy New Year,
Mark
Posted on Jan 01, 2011
  • Mark Freedman
    Mark Freedman Jan 04, 2011
    Hi, I just reviewed my solution to you and discovered that there is some more I can say to help.
    There should be a menu button on the TV itself that calls up a "setup" menu screen. On this screen select "input". At his point you can select between Video 1, Video, 2 etc.
    Hope this helps,
    Best Regards,
    Mark
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
May 20, 2012 | Toshiba 50A50 50" Rear Projection...
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
Seems to be working according to the unit display. DVD loads and plays but there is no audio or video on the TV. Menu buttons etc on the remote don't show on the TV either although they do seem to work on...
check input selection on television, and cable connections as they may have been loosened. refer to tv owner's manual for proper channel/input selection for dvd players. depending on age of tv, it may be channel 3 or 4 or it could be component1 or s-video etc, depending on how you have it connected.
Oct 17, 2010 | Toshiba D-R400
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
I have a 19 sylvania tv that I want to connet toToshiba DVD playe
If the TV doesn't have AV input jacks, you'll need an RF converter so you can watch the DVD player on channel 3 or 4. You can find them at Radio Shack, Wal-Mart, Home Depot and most places that sell TVs for around $15. Connect the audio and video from the DVD player to the inputs on the converter, and the converter's output to the TV antenna jack. Set the TV to whichever channel the converter is set for (3 or 4, with a switch on the converter so you can choose) and you'll be in business.
Sep 14, 2009 | Sylvania Televison & Video
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
How to play a DVD on my Toshiba DVD Player
Using the Toshiba's remote, select either Video (1...X, if several) or S-Video depending to what Video INput the DVD was connected to the Toshiba.
Good luck and kind regards.
Nov 25, 2007 | Televison & Video
NO MENU SCREEN ON TV
You MUST connect the recorder to the Tv with a SCART cable that is why you are not seeing anything.
I suspect you are using only the RF or Ariel Cables
If you have it connected with the scart cable you must choose the AV channel on your TV remote.
Nov 13, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
