Question about Mitsubishi Heating & Cooling
Hi, have a split system 10 years old, unit on wall has one green light flashing 5 times and repeats. Patrick
  • 2,133 Answers
E5 Communication error between outdoor and indoor
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Helpful?
Posted on Jan 01, 2011
We have a 24DMC split air conditioner and it will not start up. The green light on the wall unit flashes 3 times followed by the orange button flashing 3 times. Can u please help?
A repairman just left and the problem is, I think resolved. The solenoid on one of the mini-split units was malfunctioning. It was telling the units that it was open and functioning but was actually not working for one of the two units, and caused the main unit to shut down. Once the problem was isolated and the unit fed by the faulty solenoid was shut down, the other unit functioned perfectly. So we now have half of the cooling for the house, but better than none, until we can get the part and install it.
Jun 28, 2011 | Comfort-Aire DMC24SB Split System Air...
Just had power failure and now the green light flashes for a bit while it makes a funny noise and wiil not blow cold
Unhook the power for 10 sec and retry. If the power failure was due to a storm lightening ect could be a problem. Is this a split system or window unit. Is the green light on the furnace if it is on a split central unit or on a control panel on a window unit is it a steady flash ect...
Aug 09, 2010 | Heating & Cooling
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Flashing green light and hour glass - performs no functions
Please perform the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
May 26, 2009 | HP Photosmart 2410 All-In-One InkJet...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Open Questions:
Heating & Cooling Logo
694 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
