Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
The batteries are dead and the door is locked. How do I open the door so I can change the batteries
  • 963 Answers
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
Posted on Nov 05, 2011
Will a dead battery in a 2002 dodge grand caravan, affect if the car fob can open the doors?
Absolutely. If the battery is dead there will be no power to active the door locks (since the door locks are electrically powered). Charge the battery or put jumpers on it, you will see that the door locks will come back to life (if that was the issue)
Oct 01, 2015 | Dodge Cars & Trucks
Doors will randomly not open when the weather gets around freezing or below. Is there a fix for this? Or will getting new locks or a key fob help?
spray the door lock and mechanisms with a lubricant like wd-40 or blaster changing locks or fob will not change any thing unless lock broke or fob battery went dead
Jul 31, 2015 | Cars & Trucks
Why won't my truck start after changing battery?
Could be the security is set. Lock it up all doors. Use the key to open the drivers door. This should reset the security.
Jan 21, 2015 | 2004 Dodge Ram 1500
Cannot unlock door when battery dead
Lift the bonnet and charge the battery. If the battery is not there, use the engine metal as -ve and the alternator output lead as +ve.
Feb 28, 2014 | 2001 Chevrolet Lumina
Locked out of 2006 scion tc
when my battery died, i still able to open the door with my key, if you left it in the ignition, after the battery went dead and locked it inside , only a locksmith might be able to open the door,
Mar 24, 2013 | Scion tc Cars & Trucks
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Aug 13, 2017 | 2003 Ford Escape
Trilogy lock is dead and I do not have the over ride key. How do I open the door to change the batteries.
Here is the website for Alarm Lock, the manufacturer :
http://www.alarmlock.com/
From here you will find technical documents and a link to customer service for further assistance.
Aug 10, 2012 | Trilogy Alarm Lock T2 TRILOGY Digital...
82 benz trunk wont open dead baterry
If you use the key to lock all the doors, the trunk locks also, so if you have a dead battery, you probably don't have vaccuum to open the locks, because all the locks are vaccuum activated. Charge or change the battery and start it up, after a few minutes you should be able to activate the door locks, thus unlocking your trunk.
Good luck...
Jul 17, 2011 | Mercedes-Benz 300-Class Cars & Trucks
I think my key remote is dead and my key won't open the door. what can i do?
put a new battery in remote,try key in other door," are you sure the car battery is not dead," !!!! If it is then remote wont work, if you are locked out of car call wrecker or lock smith and they can slim jim the door to get you inside. then unlock doors USING THE POWER LOCK button PROVIDING CAR BATTERY IS NOT DEAD!!!!
Jan 14, 2011 | 1999 Lincoln Continental
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
325 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
