Question about Casio SP3 Sustain Pedal
Does the Casio LK-30 keyboard have sustain capability? It says phones/output in the back. Is there a way to get a sustain pedal to work on this model keyboard?
  • Casio Master
  • 5,603 Answers
No it does not have a sustain pedal input an there is no way to add one, sorry.
Posted on Jan 01, 2011
How do add songs to the song bank on my Casio LK-30 keyboard?
You can't add songs to the LK-30 song bank. I suspect you would need to take apart the keyboard and replace the ROM (read-only memory) chip to get a different song collection.
Most Casio electronic instrument manuals are available from http://support.casio.com/en/manual/manual.php?cid=008 . However, I found the LK-30 manual at manualslib.com: https://www.manualslib.com/manual/358460/Casio-Lk-30.html .
I wish that I had better news for you.
Sep 30, 2017 | Casio Music
Is there a sustaining pedal Casio keyboard model ctk 401
Generally, all Casio sustain pedals are compatible with all their keyboards, but i normally recomend the SP-20. SP 20 Pedals Products CASIO
Apr 22, 2016 | Pedal Music
Looking for a sustaining pedal for the Casio ctk 401 keyboard. What models will be compatible?
They are all compatible. Make sure the port on the keyboard is the same size as the plug on the pedal, usually a phono plug. Also make sure it is a sustain pedal and not an "on off " switch.
Apr 22, 2016 | Casio Music
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
The audio is not coming out what to do
First, check your volume. Try turning it up the whole way. If that doesn't work, then try moving the slider switch to normal, and playing.
Also, try using the keyboard in Song Bank mode. If you have a Sustain Pedal, make sure it's in the accessory port and not the Headphone port. If none of this works, then you may have blown a speaker. Parts are cheap from Casio ($13.00) and are relatively easy to put in yourself.
Dec 30, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Bought a sustain foot pedal and it works the opposite to what it is supposed to...have to release the pedal for the sustain effect
Yep!!! Happens all the time and only a few synths have the option of selecting the operating mode.
NOW if you can open the pedal, USUALLY the switch has both the Normally Open and Normally Closed functions that a single wire can be moved to reverse the operation.
USUALLY you will need a soldering iron to make the change.
Nov 19, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
I need a Casio LK-30 AC Adapter
Check out this link:
http://www.zzounds.com/item--CASAD5
It looks like the right one to me. I am ordering one today for our keyboard.
Aug 27, 2008 | Casio LK30 Note Lighted Keyboard
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Casio SP3 Sustain Pedal Logo
200 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
