Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
I just bought this Seeburg 160 selection Stereo Phonograph from a private owner and he told me that it worked. but when I plugged it in and made my selection it goes to the record picks it up and the needle goes to the record but than it ejects the record and goes to the next selection and does the same thing. It hasn't played anything. What can I do to get this Jukebox to play for me. Please help
  • Anonymous Mar 20, 2014
    keeps playing same record
    keeps picking up same record
    New Friend:
Also ck to see if it had a remote volume control/reject button install and the wires are not shorted together from when the wires were cut to move it.
Posted on Dec 05, 2012
  • Wurlitzer Expert
  • 567 Answers
Reject switch problem also best get the service manual tells you everything you need
Posted on Jan 10, 2012
    Problem Solver:
  • 16 Answers
OR the reject button on the back of the machine. Might be stuck or shorted. Check the wires that lead to it to be sure they aren't touching each other where they connect. Disconnect the rear reject button to see if that helps. If it does, that's the problem.
Otherwise, like above, it's probably a bad or misadjusted end-of-record switch.
In the future, please reference the model number. it's on the back of the machine on a plate, or go to www.pinballrebel.com to identify your jukebox visually.. Seeburg build stereo 160 selection machines for almost 30 years and they vary greatly.
Once again, someone bought a jukebox without watching it work first. People don't buy cars without seeing them operate. TIP! When going to look at a jukebox, take one of those long orange extension cords with you, so the seller can't use the excuse that they can't plug it in for you. Also, ask when the last time was it was lubricated.
Kyle~
Posted on Apr 18, 2009
The reject switch on the mechanism is stuck or bad its right next to the tone arm
Posted on Aug 01, 2008
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
My question is about the seeburg SPS-160 Juke Box
There is a "service switch" (bypass) that is mounted in the upper left corner (inside) of the title board (lid). It is designed to be moved in the run position when the lid is closed. If yours is still there it may be causing trouble since you moved it. This switch is often removed and covered in a ball of electrical tape and is laying in the bottom of the machine. The operators did this because the switch would frequently fail.
Troubleshooting Proceedure for this problem
1) Power off the jukebox.
2) Check the black RCA cable that plugs into the DCC (digital control center) this is labeled "Tormat" Just unplug it and plug it back in. There might be 2 more RCA connectors on the side of the mechanism control box (several black switches) Just unplug them and plug them back in. Make sure they ALL make really good connection and are tight. This cable carries the selection signal to the boxes.
3) Unplug the black and gray boxes. Examine these plugs for damage or corrosion and plug them back in again. Make sure that you check the little wire with the bullet plug located between the two plugs for the gray box.
4) After everything is back in place, power on the jukebox and see if it selects. If no result (continue)
5) On the side edge of the DCC there is a plastic cover that has test points under it. These voltages will need to be checked with a volt meter. With the power ON, touch the BLACK meter lead to the chassis (metal) and touch the RED lead to each of the screws ONE AT A TIME, be careful not to touch 2 or more of them together. Main concern is +27v, -27v, & 13v . Voltages can be + or - 2 volts.
If voltages are missing the power supply board in the DCC needs to be looked at.
If you are within 100 miles of Lancaster PA and would like a reasonably priced service call, Please call me (Ed Gardner) at (717) 333-6933 c0faecbb-5797-469a-8f9b-dea92f024201.jpg
Jan 26, 2013 | Audio Players & Recorders
When was the jukebox invented?
Gabel Automatic Entertainer (1906)
24 selections, with open 40 inch horn on top, oak cabinet. Gabel is given credit to the first coin-operated phongraph which offered a choice of selection on records.
Jan 20, 2013 | Audio Players & Recorders
My 1947 motorola tv plug is female
That would be for the phonograph power you would plug the phonegoraph into. It may or may not be switched with the main power. You would have a seperate power cord for the TV chassis itself.
Sep 29, 2012 | Motorola 1940s Vintage Portable Radio...
Oonsole model with stereo and phonograph, and phonograph will not turn on
The easiest way to find out the issue is to get an OHM reading to see if you are getting power from the switch when you select phonograph. If it is putting out, then the issue is with the phonograph, if not it is with the switch, and you will need to find a replacement.
Mar 04, 2011 | Curtis Televison & Video
Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Mar 05, 2009 | Wurlitzer Jukebox 1015 One More Time...
Trouble recording records
When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
Nov 26, 2008 | Televison & Video
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
1,216 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
