Question about American Standard Plumbing
Leaking handles on shower valve 72896n - American Standard Plumbing
  • 49 Answers
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Posted on Jan 23, 2009
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 297 Answers
SOURCE: grohe shower head is leaking. it is a glidebar
most likely ther is a cover on the handle.if the line is attached to the wall, the cover plate on the shower wall just unscrews. there is no allen key.
Posted on Jul 15, 2009
  • 127 Answers
SOURCE: I have a single handle shower valve by Moen. Water
there is a clip holding the cartridge in place. You need to remove that and then there is a little plastic throw away tool that comes with a new cartridge that you use to break the seals loose on the old cartridge....then you use a pair of channel locks to grab the stem and pull it out. The new cartridge should come with detailed instructions.
If it is a moentrol valve...the part number is 1225 and if it is a posi-temp it is a 1222. Moentrol you pull out to turn on and then left and right for temp adjustment. Posi-temp just turns to turn on and you turn from cold to hot to adjust through the temp range.
Posted on Dec 05, 2009
  • 52 Answers
SOURCE: ghrohe shower valve leaking: when in off position
Sounds like the gaskets are torn or worn out. Local hardware stores sell replacements for just about every make and model out there you won't need any tools other then some screwdrivers and allen wrenches if this is the only problem. When you open the head to inspect (make sure you turn the water main off in your house just in case) check the plastic housing to see if it's brittle or cracked. If it is you will want to replace the entire unit.
Posted on Feb 11, 2010
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Nov 05, 2013 | Maax Brio II One-Piece Neo-Angle Corner...
Leaky single lever bath tub faucet
Faucet is leaking due to seats bad.
1- Turn water off first and remove handle and remove collar that holds stem and remove it..
2- in valve there are seats that looks like caps they may be in valve body or the end of stem itself.
3- Remove them and the springs and replace them this will take care of the leaking problem.
May 21, 2010 | Delta & Single Handle Shower Faucet
Shower was leaking & tried to take apart.
those are just trim kit numbers those do not show the valve.
Apr 07, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
HOW DO I FIX A LEAKING FAUCET ON A MOEN L3189
you need to remove the cartridge behind the handle. If it is dripping from the spout or shower head.
If you pull the handle to turn it on it is called a moentrol valve and take a number 1225 cartridge....it it just turns to turn on it is called a posi-temp valve and takes a 1222 cartridge.
Oct 20, 2009 | Moen & One Handle Tub & Shower Faucet
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
55 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
