Question about Mitsubishi VS-45607 45" Rear Projection Television
Smoking tv!!! i was watching my tv and then all of a sudden the screen started flashing and then all i smell is smoke!!! i then turn off the tv, turn it on again and now there is no screen and all i hear is clicking. Someone have any idea whats going on?
  • 927 Answers
Good Day, gongora326;
It sounds like the TV has some type of short in the power or high voltage circuits.
I would recommend that you call a factory authorized service company to come to your home and give you an estimate.
I hope you take my advice, good luck, big IRISH.
Posted on Jul 31, 2008
Samsung LN46C550 TV does not turn on
There could have been a power supply failure without any noticeable symptoms.
Dec 18, 2013 | Samsung LN46C550 TV
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Aug 23, 2012 | Toshiba REGZA 37RV530 LCD TV
Have had for at least 6 months if not
What type of smoke? Did it smell electrical? Is ther a possibly of oil leaking to lower part of unit? Popcorn oil. Has the unit been submergerged when cleaning? If it is not an electrical type smoke (smell) the take the unit outside and place it on a non flammmable surface, turn it on and then plug it in. If it's oil or dishwater residue, Let it burn it off, but watch it closely. In the part you would put oil,put a cup or two of water so the heat can be absorbed. Let me know if you will please. When the element has burned off thye whatevers, It will quit smoking. If it is electrical, it will not take long for it to do nothing. You can also remove the bottom cover and take a look see for any indication of burned wiring. The smell will definateltly ID an electrical problem. It's time for a new popcorn popper if it is electrical and if it smells electrical, take it apart to verify it before trashing it uN-PLUGGED WHEN HANDLING A QUESTIONABLE APPLIANCE. :-)
Jun 01, 2010 | Toastess TCP-6L Popcorn Maker
Frigidaire window unit with heat and a/c smoke & burning smells
Hi, Anytime you turn a unit on like this and it smells and smokes, something is wrong. Did it smell as though it was electrical burning? Usually the blower motor is the first motor to go as they collect all of the return air and dust from the air and clog up the windings. They get hot and start to smoke, and you will know due to the smell of electrical wiring. I would turn it back on and see if it starts up and runs. If the motor hesitates in anyway, turn it off, or unplug it.If it is wired directly into a box, find out where the breaker is. If you are in fear of it catching on fire, call a air conditioning company out. I have seen them smoke like crazy but never had one catch on fire, never. I would turn it on, it will trip the breaker if the motor fails. Just watch it closely. If you can pull the front cover off and then turn it on, you may be able to see where the smoking is coming from, a motor ect.
Sincerely,
Shastalaker7
Dec 30, 2009 | Heating & Cooling
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Started smoking out of the back
Unfortunately RCA are a cheap and nasty budget end television. If it is out of warranty there is little you can do, apart from having it repaired or buying a new one.
The troubling fact is that it sounds like it may have been about to set on fire. This gives concern that it might be, or should be the subject of a manufacturer recall. So in your case, I would contact RCA once more and ask if your set is the subject of a recall? If they say no, say to them that you are going to contact the Recall Agency, because you think this set may have been about to burst into flames. See how fast they respond :>)
Check the link for agencies in your country.
USA consumer recalls Google Search
Mar 06, 2017 | RCA L42WD22 42 in. LCD Television
Cold weater start problem. Oil smoke in from the heater vent.
The same problem happened to me and it turned out to be my heater core.
Normally smoke will come from the heater core when it needs to be replaced.
Also the smell is most likely anti-freeze and and you normally smell it when your
engine is running warm or hot.
Check your coolant levels to be sure. and the hoses leading to your Heater Core
heater cores for that vehicle normally run $180 - $230 and you need to remove your
entire Instrument Panel (IP) (Dashboard) to replace it.
I hope this helps!
Dec 27, 2008 | 1997 Cadillac Catera
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are busted.....google it. You'll find loads of solutions!
Nov 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Watching TV and then POP!
ok, your tv is still on repairable condition,smoke that came out from your unit due to an ic that burned,I'm sure it's the vertical ic replaced with a new one.same part number.
Oct 23, 2007 | Zenith A32B43W 32" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
