My thermostat is not working. It might be locked. It's blinking with all of the information it holds flashing on the screen. The part number is: tstatccnhp01-c My heat is no longer working. Can you please help me reset it.
  • 2,133 Answers
Instructions
  1. 1 Unlock a partially locked screen by pressing any locked key, which will bring up the "Screen Locked" message. Next press an unlocked key, which will likely be the temperature up and down arrow keys. This will unlock the screen.
  2. 2 Press the "System" key from the home screen. Five blank touch keys, flanked by the "Done" and "Cancel" keys, will appear. Hold down the middle key for about five seconds. The Advanced Settings menu should come up.
  3. 3 Change the User Setup Number, found in the bottom left of the screen, by pressing the middle arrow keys up or down. Set the number to "0670," the universal unlock code.
  4. 4 Turn to the arrow keys on the right side of the screen. Press the keys up or down to change your options. Selecting the number "0" will unlock the screen, while choosing "1" will partially lock it. You can fully lock your screen again by selecting.
Read more: How to Unlock the Screen on a Honeywell Thermostat ' eHow.com http://www.ehow.com/how_7667347_unlock-screen-honeywell-thermostat.html#ixzz19ktDWSq8
Posted on Jan 01, 2011
My pioneer surround sound system has stopped working cannot turn it on and the hdmi light just flashes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Dec 15, 2015 | Pioneer Audio Players & Recorders
Display blank Sharp LC70LE650U
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 21, 2013 | Sharp Aquos Televison & Video
Flashing 4
Reprogram it and then hold down the button that says hold until it goes back to the screen that should fix it the blinking 4 is just saying you are in the 4th programming stage of the day. Mine was blinking on 3 yesterday and when I reprogrammed it it stopped blinking
Jul 03, 2012 | Hunter Fan Company 5/1/1 Programmable...
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
The number 2 remote control do not work the remote
ramoshummer,
I would need more information to provide you a specific resolution, but below I have included basic steps to programming your remote to both your TV and your DISH Network receiver.
Link for codes if needed: http://www.dishnetwork.com/SupportSection/remote-setup
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test remote and see if works.
If those don't solve your problem or you're experiencing a different issue let me know here or at thomas.faust@dishnetwork.com and I will check it out!
Tommy Faust
DISH Network
Sep 08, 2011 | DISH Network IR Remote Control
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
4402
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
Dec 12, 2010 | Microsoft Xbox 360 Console
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
When I turn on the MP3 it shows ERROR on the screen. The numbers are also blinking. I can play files from the computer the player isn't working.
chances are at some point the settings.dat file on the device has been deleted, either by file operation or by formatting. This file holds basic information about the filesystem, and can sometimes be restored by a factory reset of the device. On others, your player is now at best a usb flash storage drive.
Jul 19, 2009 | Audio Players & Recorders
Honeywell Commercial PRO TB7220U Touchscreen Programmable Thermostat wont come off screen lock and we wanna turn on air conditioning... how do you shut off screen lock?
That one is fun. Touch the system cycle button. then touch the two spaces on both sides of the center button at the bottom hold them down at the same time. After 5-10 seconds the screen should flash and show numbers int the center of the screen touch the screen til the numbers 670 appear. then change the numbers beside it to 0. then click done. now you should be able to adjust temperature as needed
Apr 13, 2008 | Heating & Cooling
Heating & Cooling Logo
600 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
