Question about Kodak EasyShare M320 Digital Camera
It wont stay on when i tur it on it only stays on for a second
  • 3,083 Answers
Chances are it has a stuck lens issue, but it could also be a power problem. The following two web blogs detail things you can try, to fix it:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
and:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If none of these step helps, you can take it into any camera shop for an estimate for repair, or contact Kodak at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=8991&pq-locale=en_US&_requestid=4949?cm_mmc=Google_MarketForce-_-Store-_-Camera%20-%20Support-_-kodak%20support
Good luck, and hope this helps.
Posted on Jan 01, 2011
Why does my 2012 dodge ram 1500 fuel pump stay on...
About 117,000 results (0.73 seconds) Search Results
    TIPM Repair & Bypass Solutions for 2007-2014 Dodge ...
    www.verticalvisions.com/TIPM_solutions.php
    2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
    Dodge Ram 1500 Questions - fuel pump keeps running ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
    I Changed The Fuel Pump On My 97 Dodge Ram 1500. Ran ...
    CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
    2011 Dodge Durango Fuel Pump Relay Stays Engaged ...
    www.carcomplaints.com/Dodge/.../fuel.../fuel_pump_relay_stays_engag...
Feb 03, 2016 | Dodge Cars & Trucks
On a 2010 ford focus, if the headlights always stay on does this mean the switch is faulty? I believe the switch is always powered and when turned on it switches to negative, causing the lights to tur
You are right about the switch connecting to ground to complete the circuit. Yes, you are also correct about the switch POSSIBLY being bad...but it might also be the relay under the hood with welded contacts staying closed and keeping the headlights on!
Jan 13, 2013 | Cars & Trucks
What's your problem?il oil light stays on
there is a oil pressure switch on the oil filter hosing did you knock the wire off when changing the filter?
May 29, 2012 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
My tv start but and fiu second tur oof
I have the same issue. TV will come on but will not stay on. I have Charter Cable. Do any others have this issue? Please help
miachellehudgens@yahoo.com
Jul 16, 2010 | Zenith R50W46 50" Rear Projection...
When i tur on my tomtom xl it wont let me continue it will just stay on the same screan
have you tried a soft reset? go to tomtom.com, select support, search for soft reset, (no info will be erased), select softreset, select your device, do as told.
Feb 17, 2010 | Tomtom ONE XL GPS
Grand wega on off
it was the very begining of the lamp burnning out , new lamp and tv good as new
wega out
Sep 07, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Hi there. i have a Sharp tv (SX68RF8) which seems to turn off (go into stand-by mode) on its own after few minutes...sometimes it stays on longer sometimes it turns off in seconds..i always have to tur it...
Sounds like something is overheating or it is getting noisy power from the mains.
Try leaving it off for a while and point a fan at it, if it turns on and stays on for longer then it is obviously a thermal issue.
Such a problem would need to be addressed by a qualified factory trained repair technician.
May 02, 2008 | Televison & Video
Kodak EasyShare M320 Digital Camera Logo
162 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
