Question about Whirlpool Water Heaters
There is no hot water coming out how do I fix it
1) You have to give more information to get accurate answer.
Is this a gas or electric water heater.
What type of heater: tankless or tank or hybrid or power vent?
What symptoms have you noticed prior to now? Less hot water than usual?
Have you installed new gas appliance that might affect gas water heater.
Did you paint floor with urethane and gas heater suddenly stopped working?
Is the circuit breaker tripped on electric heater?
With electric heater, did you open top panel and push in reset button?
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
How old is the water heater? What brand do you have and what does label show on side of tank?
Is the water heater also leaking, or is it in good condition?
2) If you don't want to answer questions for further free help, then take advantage of fixya phone service. For a price, fixya expert will ask you same questions and more questions over the phone, and then possibly help you resolve the issue.
3) If you don't want do-it-yourself help from fixya, call a plumber and give him information listed in questions above, and plumber will fix heater or install another one. The more knowledgeable and helpful you are, the more the plumber will try to help you.
4) Double-check information you receive from fixya and from professional plumber by posting question on professional plumber's forum like the Tank: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Jan 01, 2011
My hot water heater heat water up but dose not come out of tank how can I fix it
check the inlet water supply if it goes in it has to come out
Jun 13, 2015 | Water Water Heaters
My hot water to the shower goes cold after 3-4 mins could please help?
a couple of things to check on the side of the hot water system you will see a valve with a small lever
lift that lever until there is a solid stream of water coming from the pipe
that ensures that the heater tank is full
next -if you have a temperature mixer on the hot water pipe out of the tank ( stops scolds in the bath, shower sink) by controlling the temperature mix at the tank
They are known to fail and shut down the hot water supply by adding extra cold water into the system
other than that get a plumber in to fix the fault.
Apr 20, 2015 | Water Water Heaters
My hot water is fed from the emersion fed from the boiler and is very slow and takes an age to get hot in the kitchen any idea's
Sounds like minerals are built up in the lines and restricting flow.
The fix is changing out the lines in question. So if your coming from the basement these pipes usually travel through the floors and walls and can be a real pain, Sometimes going outside the building with a new pipe (will have to be wrapped with pipe insulation) and come back into the building in the room or rooms where the hot water is needed. The easiest fix would be to get hot water on demand set up that installs under the sink or in the room where needed. The cost is a factor in the last fix. ........~~~~~*BB
Mar 02, 2015 | Water Water Heaters
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Our tankless water heater is about 3 yrs old and when you take a shower the water is so hot it will burn you and when you try to cut more cold on it turns all the way cold we have it turned down as low as...
almost all tankless water heaters have this problem. I would install a small "buffer" tank. for example a small 5 or 10 gallon electric water heater will "mix" the water so that it doesn't come out of your shower cold, or scalding hot.
the instructions that came with your water heater should have a diagram of how to do this. if not let me know, I can send a copy.
the electric water heater acts as a mixing station.
the problem with most tankless heaters is that the water coming in is cold, average 60* and the water coming out is average 120*. sometimes the flame in the unit can't keep up when using large amounts of water, and you will get cold spots. when this happens, the heater will sense this, and then tells the flame it needs more BTU's, so then you will get extremely hot water.
the buffer tank will fix this by mixing the water before it gets to your shower and will give you an even water temperature.
let me know if this helps
Aug 22, 2010 | Bosch Water Heaters
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
103 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
