Question about Linksys Wireless-G WRT54G Router
I have a Linksys wireless-G 2.4 GHz router directly connected to my PC. I've just bought a MacBook Pro and want to go online via this router. The Macbook finds the router but cannot connect to internet. What can I do??
  • Vern Haynes
    Vern Haynes Jan 01, 2011
    Do you know what Wireless authentication protocol you are using on your Linksys? You might want to use an open (no authentication) protocol, as a means of testing connectivity. If it works with no authentication, then I would suggest switching to a different protocol such as WPA or WPA2 (not sure what protocols macs use, but I would guess that WPA/WPA2 are supported protocols)
    Master:
  • 397 Answers
The reason you cannot connect, is you have to match the settings from your router to Airport- usually it requires you setting the security on your router to a specific WPA2, Wep, or no security- invariably I have had trouble getting clients to get online with the WPA2 set to the either or setting- but set it to either public or private- they're online. Anyhow, in order to do that- you will need to log into your router- if you have a pc/mac hard wired into the linksys via ethernet, open a web browser window and go to 192.168.1.1- it would be under wireless security. Match the settings on your Macbook, you should be able to go wireless at that point. Another solution, depending on your internet service provider... is that the provider could share your system remotely and assist with getting you online wirelessly (I know for a fact that Verizon DSL Business does do this. )
Posted on Jan 01, 2011
Why does my macbook pro keep disconnecting from wifi?
your in an apartment an there are several more 2 ghz wireless near , you can change channels on the router an that will help.
they have a default .
this means every machine needs to be changed that contact the router wireless.
or get dual band router an a 6ghz cisco usb wireless 10.00 adapter from amazon
Jul 25, 2014 | Apple MacBook Pro Laptop Computer with...
Is too short for her MacBook Pro. -Thanks.
I would recommend purchasing a newer router that is more powerful. The Apple Airport Extreme is a fantastic router. If none of these choices work then you can either connect your Macbook via ethernet or move it closer to your router. here is the Apple Airport Extreme. http://store.apple.com/us/product/MC340LL/A/AirPort-Extreme?mco=MTY3ODQ5OTY
Dec 19, 2010 | Linksys WRT54G Wireless-G 802.11g...
Bought wireless router without software
ec1.images-amazon.com/media/i3d/01/.../MANUAL000000300.pdf
Yo do NOT need special software, you simply access the unit via the Ethernet port and a Browser. It is all shown how to do it in the manual above.
You log into the router by typing in it's address and a default log on and password, Then you setup your connection, as i said please use the manual.
You need your Logon details and your password for your INTERNET connection,
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
Will not connect to internet whether it is wired or not
connect the broadband modem to the internet port of your router (probably is blue). Then connect your pc to the router.
You have to set your router to act as dns.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
I just bought a new iMac 3.06 Ghz and it won't connect to my wireless ZyXEL G-570S router. It can see it, and I know absolutely that we DO NOT have a password on it at the moment, as I had reset...
Hi Peg,
I'm sorry, the chat session ended by itself and i was not able to rejoin the session. As you wrote the that all non mac are able to go online wirelessly . Could you also let me know if you plug the Mac using the network cable or the ethernet cable is it going online.
Thanks
Proton
Aug 31, 2008 | Computers & Internet
WRT54G ver. 6 wireless router linksys
Hi margue,
What is the firmware on the router ?
Check the updated list of firmwares here.
For instructions on upgrading the firmware, click here.
After upgrading the firmware reset the router for 20 seconds.
After resetting the router, follow this :
  • Connect the computer to the router.
  • Open the setup page. Default password is admin.
  • In Setup, click on the subtab, MAC Address Clone.
  • Click Clone. Click Save Settings.
  • Turn OFF the Router and the Modem. Wait for 10 seconds.
  • Turn the Modem ON, wait for 10 secs.
  • Turn the Router ON.
  • Try going Online. You should be ONLINE !!!
  • Click on the Wireless TAB, change the name [SSID].
  • Change the channel to 11-2.462 GHz.
  • If you want to enable wireless security, go for WEP 64 bits.
  • Read this article about Wireless Security.
Hope this helps mate !
All the Best.
http://linksysfirmwares.googlepages.com
Jul 31, 2008 | Linksys Wireless-G WRT54G Router
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Linksys Wireless-G WRT54G Router Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
