Question about Cyberhome DVD Recorder - DVR1600
No Disc My problem is I get a no disc when trying to pay a existing DVD I have some succes when I open and close the DiscTray a numder of times whats the solution Ron
  • 6 more comments
  • Anonymous Jul 21, 2008
    when record from vcr i lose everything when i try to finalize disc it pop up unknown disc. when fist put a new disk in its say fomat i click yes,what willl happen if i click cancel
  • domv Aug 25, 2008
    have same problem reads no disc
  • domv Aug 25, 2008
    insert disc - screen reads no disc
  • Anonymous Oct 20, 2008
    Have the same problem. "No disc" with blank or prerecorded DVDs.
  • jgnomikos Dec 09, 2008
    Starts with LOAD when I put a dvd to play and comes with NO DISK FOUND....
  • rsands22 Feb 20, 2009
    When I put in any DVD it reads load, I hear the disk searching, finally it says no disk. Once in a while it will play a DVD, I thought the answer was slapping/jarring the unit, I did this once and it played the DVD, but it wasn't a consistent fix. When it played the DVD, it kept stopping, pausing, then playing. The video when playing was excellent. The lens has been cleaned. The unit will play CD's with no problem. Any help will be appreciated, ah that is, beside junking the unit.
  • Anonymous Feb 24, 2009
    no matter what type of disc, the machine attempts to load then reads no disc
  • switchblade0 Mar 06, 2009
    My problem is I get a no disc when trying to paly a existing DVD
    whats the solution
    SM
I have a Cyberhome DVD Recorder (DVDR16D) when i put in disc it reads no disc on my TV. any solution?
Posted on Aug 19, 2008
  • 3 Answers
You need to repair the power supply.Need to change the 2200 mF and 1000mf capacitors with a higher voltage either 25 or 35 Volts.And for beeter results to install a small CPU fan with holes to vet the warm air from the power supply.
Good Luck! Any more info needed let me know!
Posted on Apr 14, 2009
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Long loading time, then readout says, bad disc.
The lazer beam of the disc has a micro dust that need to remove. You can try to use the cd cleaner. If nothing happen , you need to open the disc and spray the lenses with soft air.
Jul 26, 2009 | Cyberhome CH-DVD 300 DVD Player
Hard drive disc will not open, after dl free dvd disc burning...recorded then will not eject...tks
It is free to download the program,its not free to install the set up file!
just the way it is,you need search for freeware,not free download.
Which dvd are you trying to download,I may be able to point you in right direction
Apr 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Sony 5 disc dvd player - discs lock in - spinner needs push to go
You can spray WD-40 contact cleaner but very little amount in spindle motor (you call it spinner) and please take care, DO NOT spray over optical lens which is so close to spindle motor.
If problem still exist, you need to replace optical lens assembly and I will provide you part number if required.
Good Luck.
Jan 15, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
409 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
