Ups is not getting charged - Computers & Internet
I have just installed a smart 15kva apc ups but the battery keeps showing red even though it is on charge.
Posted on Aug 17, 2011
  • 23 Answers
The UPS battery could be dead. If the UPS is older, that is probably the case. You can get replacement batteries but they can be expensive.
Posted on Jan 01, 2011
Battery port
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
Aug 24, 2016 | Tablets & eReaders
My fitbit charge gets stuck on the finishing up step.
I'm having trouble setting up my tracker using ... - Fitbit Help
help.fitbit.com/.../en.../I-m-having-troubles-setting-up-my-tracker
FitbitJul 31, 2015 - I'm having trouble setting up my tracker using my computer ... If you followed the steps in How do I set up my Fitbit tracker on a computer? and couldn't complete ... Your tracker is charged. ... Or, if you'd prefer to get in touch:.
Oct 31, 2015 | Cars & Trucks
My htc one mini isn't turning on, But it comes up with the battery sign? What's wrong with the phone?
It sounds like you need to charge it up.the charge icon usually means there is insuffient power to switch on.it may be the battery isn't charging properly I.e. The charger is faulty...the charging point is faulty...or the battery is no longer holding a charge.sometimes if you charge abroad or on say a ship where the amp of the circuit is less the 500 mah the charging behavior changes and it takes a few attempts to get it to behave normally.
another thing you might try is change the charger to a more powerful one just to give it a boost.i.e. Instead of using the normal 5 volt 1amp try a charger with 5volt 2 amps.once the battery reaches at least 5%. It should start up.fully charge and then try to get into the habit of running phone down to 20% and up to 80. % instead of continuously charging each day when the phone is still holding a healthy percentage?only once in while should you run below 5% and then charge to 100% .incidentally most batteries start to lose their stamina after 500 plus charges.
Feb 05, 2015 | HTC Cell Phones
My iPhone 2g is heating up..and if i charge it its so hot and i will take me 1 day to fully charged it and if not fully charged i can used it up to 20-30 munites if fully charged 2-3 hours and the hot...
You either have a bad battery or you have a bad charger. If the phone heats up when you plug it into the USB port on a computer then you know that the battery is bad and needs to be replaced. If the phone does not heat up and you get a normal charge from the USB connection then you know that the battery is good and the charger is bad.
Mar 24, 2011 | Apple Iphone 2g 3g 3gs 8gb 16gb S
The charging port was lose to begin with whenever i would plug my batt. charger in it. then one day I was jiggling around to get the phone to charge pulled it out and pushed it in and one of the metal tabs...
Hello
If one of the metal is bent up and your phone is not charging then you would need to replace the charging port of your phone.Before replacing the charging port you could use a desktop charger for the main time while you get your charging port replaced.
GOODLUCK
Jul 02, 2010 | Motorola Mobility W385 Cellular Phone
BATTERY IS BAD. CHARGE CORD HEATS UP. REPLACED CORD AND CHARGER LAST YEAR
Compaq chargers get heated up a lot when charging. This is a common problem.
Based on the issues you mentioned, unfortunately you would need to get the battery changed.
Regarding the charge cord getting heated up, try keeping it on a concrete/cold surface to lessen the heat. Unfortunately nothing more can be done about it, and as i said compaq chargers do get heated up quickly.
Thanks.
Feb 03, 2010 | Compaq Presario M2000 Notebook
Compaq presario v4000 laptop won't power up, but battery charge indicator light flashes 3 times when power switch is depressed
I had a Hp or compaq tablet *with swivel screen. I have a hard time myself trying to get it to beam up. what a pesky switch. But I do know what happened to it before it started acting bad.... the spot where I plug in the power cord got extremely loose.. and i had to hold it just so with one leg of mine in the air one under me.. :D joke but you get the point. Just to try to get it to charge up. I didnt know if it was just the plug... I found out later with the help of a charging dock. That it was in fact the chargeing hole... After about 5 hrs playing with the cord in the charge dock to get it just right. It charged up for a measly hr or so. But since then when I use the charge dock the laptop will boot up...
Oct 02, 2009 | Compaq Computers & Internet
UPS won't charge through a voltage converter
the UPS batteris are dead and you will not be able to charge them. the batteries cannot be repaired so either get new batteries for the ups or get a new UPS. the UPs have a life, after which their batteries die off and do not charge as in your case.
Aug 04, 2009 | CyberPower BC1500D 1500VA 900W UPS W/AVR...
IPOD 2GB LOCKED UP
let it charge fully
if it doesnt charge, then the USB cable is bad
the pins can be pushed back and wont charge
so get a new cabel and get it charged!
May 29, 2008 | Apple iPod nano
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
