Question about GE JTP48 Electric Double Oven
My GE JTP48 oven is having a F7 code pop up and it is very difficult to get the oven to turn on. We do get a beep when we push clear but no other button makes a sound.
localwonder
  • 6784 Answers
SOURCE: F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Posted on Jun 24, 2009
  • 56 Answers
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Posted on Aug 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Posted on Mar 09, 2010
SOURCE: F7 error message on GE oven
one other comment about the F7 message having delt with this stupid oven for years and after replacing touchpads and controls the touch pad is the cause of the F7 in one of 2 ways either the ribbon cable is shorted (the repair for this has been posted by several people and is good) or a stuck button .One cause of the stuck button at least in my house has been steam coming from the oven flowing over the touch pad this can get moisture in the touchpad shorting it out causing a button to stick giving an error message also making the oven unusable....what I did solved the problem I figured I was going to have to spring for a new touch pad so I peeled it off the front of the oven got under the edge with a knife and lifted it off (it is stuck on fairlly well but will lift off) once this is done i squeezed every button between my fingers and flexed the touchpad back and forth (flexed not bent) ..I noticed the edges are not sealed well allowing moisture between the mylar surfaces poor design! i replaced pad and sprayed edges with silicone spray soaked the front also around the window area figuring the silicone would get between the surfaces and help prevent this problem Ta Da oven all better too bad I didn't figure this out sooner but I hope this helps someone....GB BodhaineG@aol.com
Posted on May 08, 2010
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | GE Ovens
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
Jul 30, 2009 | GE JTP45 Electric Double Oven
The screen ready f7 and beeps every minute, What does it mean
F7
Jul 16, 2009 | GE JGRP17 Gas Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Double GE wall oven - F7 code
You either have a stuck touch pad button or a bad clock.
Push all buttons several times to try and clear.
If not successful repair is a new clock.
Feb 22, 2009 | GE Ovens
GE JTP48 Electric Double Oven Logo
57 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
