Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Refrig and freezer won't cool
Posted by crappie16 on Jul 08, 2008 Report abuseWe had one solution posted, but I wanted to see if you could comment. Thanks
Refrig and Freezer will not cool. Installed 6/21/2005
Any suggestions?
Comment by crappie16, posted on Jul 08, 2008 We did hit the reset button (inside refrig) and put the temp setting on max. Unplugged, let it set then tried again. However no cooling. There is no frost buildup, clean underneath.
I can hear a fan blowing from the location of the compressor, but I can't tell you I heard the compressor kick on.
  • intuit500 Dec 25, 2008
    I have a problem with the refrigerator and freezer not cooling on a Kitchenaid Superba KSYg25f. It is about 8 years old. I noticed a burnt smell and inspected the compressor relay/over load burnt terminal lugs. I replaced with very expensive kit. The compressor runs now but still not colling at all.
    Any ideas?
  • 481 Answers
If it is not cooling at all then i would suspect the compressor is not running. this could be caused by the start switch on the side of the compressor not working. as a first step i would take off the start switch and inspect it. sometimes you can tell just by looking at that it is bad (melted plastic or burn marks or pieces rattling inside). let me know the results so we can go to the next step if needed.
Posted on Jul 08, 2008
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Ed2vhex side by side won't cool on refrig side. Freezer side is cold. What is the problem. It is under warranty.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Whirlpool ED5VHGXM Side by Side...
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Not printing 9
Instructions please for brother AX-25 typewriter electric
Jul 13, 2008 | Office Equipment & Supplies
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
98 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
