Question about Samsung Refrigerators
I have punchured the gas line in the ice box - Samsung Refrigerators
  • 958 Answers
Im sorry hyundai getz but if you punctured the gas line in the ice box and the gas escaped, then you will need a profesional technician to repair the line and recharge your system again in order to work.
we can not solve that problem this way.
Posted on Jul 08, 2008
I cleaned the ice cube box & returned it to the RF20 Samsung fridge. Now it does not make ice cubes, Why?
Try re-seating the ice cub box, and make sure any ice maker moving parts, such as the ice bail wire are properly positioned and move freely. Sometimes the actuator and ice cube box do not line up correctly.
Make sure the ice cube box parts move freely.
Mar 11, 2015 | Samsung Refrigerators
I have GE side x side cannot get ice to make or water thru the door I have changed ice maker and water valve also have made sure I have water to refrigerator and no frozen lines so don't know
if this box is a 2001 or newer it has a filter in water line. if this is it take filter and bypass that whole filter. also these boxs have main control located back of box and all fuctions go thru this board. If older than 2001 check icemaker were plugs in. You can force ejectors to make the ice maker run. cycle icemaker check for power at water valve. The ice maker valve is the small line
Sep 19, 2014 | Refrigerators
Brand new battery on 1995 VW Jetta keeps being drained and car shuts off.
Have you had your alternator checked ?
If there is no charging from the alternator the "problem" will be solved as long as the new battery retaing its voltage. As soon as you start to use power you drain the battery. it's a bit like putting air into a punchured tyre ..... its still punchured . Could be your original problem ! ! Good luck
Aug 01, 2012 | 1995 Volkswagen Jetta
Iam working on a hoshizaki ice maker, turn it on make one batck of ice, after that, my cooper lines on bottom of coils were warm and o n top od the coil were hot,whar could be the problem?
On Hoshi ice maker, if coils are HOT, it is passing hot gas from compressor into the lines. After the defrost of the first cycle, after this cubes are completely cleared from the plates, the "Hot Gas Valve" should close and the freeze cycle should start over. It sounds that the valve is sticking open and not stopping the hot gas from entering. Look there first.
Sep 10, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Heater don't swith for defrost to anything else Cecked vac line and wiring all OK So what next?
you need to check the vacuum diaphram to make sure its not punchured
Feb 03, 2011 | 1999 GMC Sonoma
The refrigerator is 2 yrs old and has completely quit cooling in both the refrigerator and freezer.
I looked at your wiring diagram. This ice box has automatic defrost controls. That means the temp is regulated by a computer board. Their are some diagnostics you can perform on some of these models.
Your ice box appears to be a midrange control model. Click HERE for a diagnostics video
Amana International bottom mount service manual featuring midrange electronic controls
Jan 27, 2011 | Amana ABB1927DE Bottom Freezer...
Some times suctun line ice forming but gas is ok hy?
icing bad or just abit? its normal to have water on it if its icing under the black foam insulation you have a gas problem gas leak, or a fan not working
Nov 10, 2010 | Mitsubishi MS-A09WA Split System Air...
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
Hello I have a 1960 general motors fridge. I was breaking ice off the ice box and punctured the outside box and all the gas escaped. Can you help me?
dear best solution is change the old ice box.if you can not this then repair the box and then fill the gas from repairing shop.thanks
Aug 22, 2009 | Refrigerators
Gas grill regulator freezing
I do not understand the term " regulator and gas line from the regulator ice up" Do you mean ice up as in frozen water? I do not know where the water would come from. Is there a drip leg on your gas piping? A drip leg is pipe nipple placed before the appliance.
fireguy
Apr 14, 2008 | Kitchen Appliances - Others
Refrigerators Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
