Question about Dynex 400-Watt ATX CPU Power Supply
I just installed a Dynex 400 Watt power suppy dx-400wps, it fits perfect and i've connected everything but when I plug it in i get nothing.
5 Suggested Answers
  • 2666 Answers
SOURCE: installing a new power supply unit
Nothing to worry about, there are always extra connectors for different configurations.As long as you have the 24 pin and 4 pin connected to the MoBO and your CD/DVD drives and HDD are powered you'll be OK
Posted on Jul 30, 2009
info2u
  • 596 Answers
SOURCE: Need help fixing Dynex 400-Watt ATX CPU Power
Exactly what do you need help with?
thanks
C2Solutons
Posted on Aug 19, 2009
  • 512 Answers
SOURCE: will a dynex 400 watt atx cpu power supply work in
It should plug right in since the 8300 uses an ATX pwr sply.
Posted on Sep 03, 2009
leethedeuce
  • 4472 Answers
SOURCE: I have an Acer Apire
Then all you need to do is replace the same connections with the connections that are currently plugged in and then plug in the hard drive, dvd drive power cables as well, just look at the plug you disconnect and then plug in that cable with the new power supply you can have the power supply sitting outside of the computer it doesn't really matter just make sure you all the power cords plugged in including their should be small one for the processor fan.
here are a couple videos that should help you;
Thank you,
Lee
Posted on Aug 31, 2010
I have the dynex 400 watt atx power supply,connector do I use my sata connector.
They try to make them "idiot proof." Only the correct one should fit in the power receptacle on the dvd/cd player.
Try the different ones and don't force anything...
Mar 09, 2014 | Dynex 400-Watt ATX CPU Power Supply
Turning on my computer by pressing the On/Off switch on front of desktop computer does not always turn machine one.
more likely the switch itself not retaining the on position
get to the switch and bridge the 2 wires to see it it stays on
Jul 21, 2017 | Dynex DX-400WPS 400-Watt Power Supply
Will this replace the dynex dx-ps400w2 power supply
  • Yes.
  • Please reply if you have any more questions. Good luck, Cooper. (Please give a thumbs up, I am doing this for a summer job!)
Jul 07, 2011 | Dynex DX-400WPS 400-Watt Power Supply
Had a mge350wps, burnt out, replaced with dx-400wps, turns on but receive messages as follows. NTLDR IS MISSING PRI MASTER DRIVE (NONE) DISKETTE DISK A(NONE) DISKETTE DISK B (NONE)
As long as everything is plugged in you may have had a surge from the old power supply that damaged the drives. I have seen this happen. I hope it didnt happen to you but it may have. Do you have power to the CD/DVD drive. When you start the computer does a light come on on the front of the drive? Push the eject button on the drive and see if the drawer comes out. This wont eliminate the possibility of a damaged but it might help diagnose if your getting power to the drive. You should also listen to see if your hard drive spins up. If you disconnected the drive cables from the mainboard or from the drives make sure they are back on the correct direction. You should also try the system with just the Hard drive plugged into the mainboard. Since I have had a single bad drive make the system not boot correctly eliminating all but the main drive will help you see if it is a bad drive making everything not work. Dont forget to go into the BIOS and set all drives for Auto.
Hope this helps... Dale
Apr 21, 2011 | Dynex DX-400WPS 400-Watt Power Supply
The fuse is blown and the Model DX-PS350W is discontinued - what other power supply can I purchase that is compatible
you can use about any power supply you want as long as the physical size is the same. stay away from the really cheap ones. they weigh half of what a good one does and they cause problems with the computer. i did see amazo has a 400 watt Dynex on sale now, here is the link
http://www.amazon.com/Dynex-DX-PS350W-350-Watt-Power-Supply/dp/B000EVOOWA
also newegg.com is a trusted site to buy computer parts they sell the cheap ones as well as the top of the line and most all have user reviews.
Feb 14, 2011 | Dynex (DX-PS350W) (DXPS350W) 350-Watt...
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
I recently purchased a Dynex 400 watt atx power supply for my Dell optiplex gx280 (slim form). The reason I did this is I have a new PNY geforce 8400 GPU and my old power supply is only 160 watts (1/2 the...
Sounds like the power supply is not compatible with the motherboard. If the motherboard can't support a 400 watt powers supply you will either get a blinking light or nothing at all. Those optiplex's use a proprietory power supply because of the pin connectors and how a power supply is supposed to fit in there. If you can't find a 400 watt power supply that fits then get a hold of Dell and see if they sell one for that computer.
Sep 22, 2010 | Dynex 400-Watt ATX CPU Power Supply
Installing a new power supply unit
Jul 30, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
Need a power supply to replace a Dynex DX-PS400W
Any power supply with the same pins will do. Just choose a good brand and with same rating or better higher(400 watts or more).
Sep 14, 2008 | Dynex Computers & Internet
Open Questions:
See all Dynex 400-Watt ATX CPU Power Supply Questions
Dynex 400-Watt ATX CPU Power Supply Logo
142 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
