Question about Mastercool 67680 Evaporative Cooler Air Conditioner
I'm trying to get in touch with master cool! There is big rust holes that went all the way through. This is the worst swamp cooler ever. $1400.00 that included insallation. The spider bearing doesn't freely move. I cant get the bearing off, the one to the motor, just the inner of the bearing remaims. what can i use to repair these rust holes. This is on the roof.
  • 40 Answers
Buy a Braemar. You get what you pay for. buy a better cooler. get a better result
Posted on Apr 04, 2011
We have a marquis swamp cooler don't know how old
Your blower motor, or pump motor, or belt has failed.
Jun 21, 2013 | Heating & Cooling
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
NEED TO KNOW HOW BIG AN AREA A 10,000BTU SWAMP COOLER WILL COOL.
That will cool a normal size room. The cooling capacity depends on a lot of things like how well insulated the room is.
Jul 20, 2010 | Mastercool Portable Air Conditioner
Bought used - want to prevent rusting of water trough and other
If you can get to the whole water trough to coat it, I recommend you get some spray undercoating or a product like "Phil Swift" promotes on TV and spray it on the affected area.
Mar 29, 2017 | Mastercool 67680 Evaporative Cooler Air...
Water on the squiral cage side I don't know where its coming from
I don't know exactly what you mean by getting water on the dry side of the compartment. In any event, as you will see, there are very few sites that are dedicated to the maintenance and repair of evaporative coolers--you, in fact, submitted this problem of yours under the Air Conditioner section because there is no Evaporative Cooler section.
Having said this, I offer you two things: 1) a site that has a section dedicated to evaporative coolers, which took me a long time to find for my own problems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
and 2) the general idea that if you have water where it is not supposed to be, it likely is because there is a hole---obviously caused by rust--that allowed such water to get penetrated through. See more on rust holes of coolers here:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Has_Holes.htm
This should help get you on your way.
Brad
Jun 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
135 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
