Question about Sylvania 6432GG 32" TV
My tv is stuck in diagnostics mode how do i get it off
Error code 12 for: Mitsubishi WD-73737 DLP TV Just replaced bulb – tv turns on but is stuck on Welcome screen with flashing green light. I did the :10 reset but no luck Any answers?!
Check YouTube for video about error codes and adjusting screen parameters. There is a certain sequence and button combination to put you into diagnostics mode. Hope this helps you.
Jul 11, 2016 | Mitsubishi Televison & Video
Speakers stuck in diagnostic mode, know how to get them out of it?
The user manual states to plug the sound cables into the correct sound output jacks of the sound card of your computer to get the speakers to come out of diagnostic mode. I am guessing that once a signal is picked up on the audio cables that the speaker will switch modes.
Jun 12, 2014 | Harman Kardon HK695 Computer Speakers
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Dec 26, 2010 | Whirlpool Duet Front Loading Dryer Rack...
Guessing it is stuck in diagnstic mode 1998 dodge gr. caravan 3.3
there is a module that needs reprogrammed,this happens all the time
Feb 03, 2009 | 1998 Dodge Grand Caravan
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Diagnostic Mode?
Press and hold power & action button on front of tv hold untill tv turns off release - Set will come back on with other menu just press channel up . this should clear setup mode.
Nov 18, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
Nov 10, 2007 | Mintek DTV-323-D TV
Sylvania 6432GG 32" TV Logo
29 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
