Question about Sunbeam Health O Meter Body Monitoring Scale
Sunbeam ps6600 err 1 comes up all the time. put in new batteries still doing the same thing. What is the solution?
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: "Err" message on Sunbeam breadmaker
Checked the manual but no info in http://www.sunbeam.com/Manuals/MANUALS/005891-000-000_43_4357793.PDF
Would suggest checking with your local Service Center, locatable via http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Posted on May 25, 2010
Even with new batteries is reading as- Err 1 and does not display my weight in Kgs
take the batteries out and clean the compartment rreall good if that doesnt work try holding the off button for 25-30 seconds with batteres in if that doesnt work try it with the batteries out if that doesnt work look for a little hole behind where the batteries go and put like a little pin or somnthing in that little hole wait like a minute or a minute and thirty seconds if that doesnt work bring it outside put it on your driveway go in your garage grab a sledge hammer and smash that dam thing to pieces b/c its broke theres nothing you can do expect bring it somewhere to have it internally fixed by some scamm when it will be cheaper to go buy a new one
Apr 14, 2011 | Sunbeam Kitchen Ranges
I have tried many times over the last few days to take my blood pressure with your monitor...it continually comes up ERR. My husband takes his in exactly the same way with no problem.
there are many possiblity
(1) your arm size does not match with the cuff that comes with the machine, you need to get one fit your arm size
(2) your pulse is to weak for the machin to measure the reading
Jan 05, 2011 | Sunbeam Digital Blood Pressure Monitor
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Food processing. I wish to feed eg. carrots, parsely, pumpkin,
If you're in Australia there are some Sunbeam models that have a continuous flow attachment where the chopped items don't have to end up in a bowl you have to continually empty.
The Sunbeam Oskar™ 400 Model LC2700 can be found at http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1352
The Sunbeam Cafe Series LC8900 http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1360 has a similar attachment that can be bought as an accessory. LC0800 http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1351
Now I'm guessing you're not in Australia but at least these things do exist! By the way I don't work for Sunbeam but have ordered this type of thing in for customers.
Apr 03, 2009 | Food Processors
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Nissan stereo sy702 with constant err flashing after flat battery
WRONG! Leave the radio on for 1 hour using the key and accessories to reset then enter the pin. You get the pin from nissan customer service in your area but you need to supply your vin/chassis number.
To enter the pin you press buttons 1-4 corresponding to the number of the pin eg. pin is 1023, press button 1 once, 2 ten times, 3 two times, 4 three times
Jan 03, 2009 | 1992 Nissan Pickup
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
Nov 10, 2008 | Kidde Nighthawk Combo Gas/co Detector
Cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Jun 16, 2008 | 2000 Renault 181
Sunbeam Health O Meter Body Monitoring Scale Logo
133 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
musquodoboit
musquodoboit
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
